USB2ISA? I'm Skeptical...
Reply 20 of 44, by cyclone3d
Benedikt wrote on 2020-09-10, 10:48:
cyclone3d wrote on 2020-09-10, 07:59:
I haven't actually tried it with an ISA card yet but it looks like it will auto detect resources... at least on non-pnp cards. I think you may have to manually add the needed resources for pnp cards from the looks of it but not 100% sure.
Not the other way around?
Don't think so. PnP cards usually require at least an initialization program to initialize the card and get/set the resources. Non-PnP cards' resources are set by jumpers.
So the enumeration program will most likely not detect the resources or at least the proper resources since the card has not been initialized yet.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 21 of 44, by cyclone3d
Here are the results of some resource detection tests I just did on non-PnP cards. Looking very promising:
Sound Blaster Pro 1.0 CT1330A rev 6:
39.35 KiB
Sound Blaster 2.0 CT1350B:
37.49 KiB
Sound Blaster 16 CT1740:
38.4 KiB
TexElec Resound OPL3 v1.1:
36.28 KiB
YMF7x4 Guide
Reply 22 of 44, by matze79
https://www.lo-tech.co.uk/product/isa-usb-adapter-pcb/
The Lo-tech ISA USB Adapter is a bootable storage adapter for IBM PC, PC/XT, PC/AT and compatible hardware – essentially any PC with an ISA slot, enabling a standard USB flash drive to be used
but it`s slow.
There remakes on Ebay some Times.
Instead of CF Card, CH375 with USB Drive is used.
Reply 23 of 44, by cyclone3d
Ok, so to get sound card passthrough working I am going to have to do a custom build since stock 0.74 doesn't support passthrough.... or does it?
I'll start with OPL and then see if I can get digital output to passthrough as well.
I'll see if I can get MIDI passthrough to the USB-ISA adapter as well.
YMF7x4 Guide
Reply 24 of 44, by cyclone3d
Was looking on the arstech site and saw one of their FAQs
- Can I use other external power supplies?
If you know that your isa card needs additional voltages and consumes high currents - when you power it with a switching power supply it may introduce power noise , which may exceed the usb signal level - and crash the system .
For testing purposes you may use one of our external supplies - isa-pwr-x2, isa-pwr-xr, isa-pwr-ec .
Guess this explains why when I hooked up the other power supply I bought, which is a switching power supply, make the CT1350B have a ton of noise. Guess I will be ordering one of their power supplies.
YMF7x4 Guide
Reply 25 of 44, by Tiido
Majority of power supplies are switching type, the days of 50/60Hz transformers is long over. If you got noises etc. in the sound it is due to poor power filtering in that PSU that was used. Higher quality things don't have such a problem (but if CT1350 will be interference free is questionable, those cards are designed wrong which is the primary reason for the interferences people usually get on them).
Reply 26 of 44, by cyclone3d
Well, the noise is when the card isn't even playing anything. I have never heard a CT1350B output that much noise. It is like a high-pitched squeal.
I went ahead and ordered one of the 50w power supplies from arstech even though the price was higher and they charged a dumb amount of shipping. My guess is that they are linear (50/60Hz transformers).
Ended up shipping to my work address since it was cheaper than shipping to my home address.
Guess I'll see if it improves the noise output when it gets here.
YMF7x4 Guide
Reply 27 of 44, by darry
cyclone3d wrote on 2020-09-12, 01:31:
Well, the noise is when the card isn't even playing anything. I have never heard a CT1350B output that much noise. It is like a […]
Cheap switching PSUs can be full of surprises and Creative Labs cards can be particularly susceptible to their charms . I just learned that today . See Re: [SOLVED] Apparent ground loop between devices connected to a single AC circuit (same outlet, actually)
Reply 28 of 44, by cyclone3d
darry wrote on 2020-09-12, 01:36:
Yeah, but this was a Meanwell power adapter. Not cheap either. Guess I should have looked at the FAQs before ordering it.
Anyway, I just want to get this thing working with dosbox and sound cards and don't want to have the wrong power supply possibly screwing it up.
YMF7x4 Guide
Reply 29 of 44, by darry
cyclone3d wrote on 2020-09-12, 05:45:
I guess they "meantwell", at least. 😉 Seriously, though, finding I reliable and trustworthy source for wall-wart type PSUs is harder than I thought . I have actually been lucky enough to accidentally buy one which ended up having a fake UL number on it at one of the biggest musical instrument retailer chains in my area (got a refund) . For audio/video purposes, my strategy so far has been to try to buy OEM branded ones by Yamaha, Roland, etc from an authorized distributor. The theory behind this that if it's meant for a musical instrument or audio gear and branded by the OEM, it is likely fit for purpose (proper filtering, regulation, sometimes even a current limiter). The PSU that I was using with the OSSC (a clone OSSC, bought during the worst of the COVID induced mail slowdown, so I got it through Amazon in order to have it fast ) was the one bundled with it, which caused no issues except with my AWE64 . While testing, I was able to stop the noise by either turning off the OSSC, unplugging the OSSC from the still powered PSU, unplugging the VGA cable from the OSSC or unplugging the HDMI cable from the OSSC .
Reply 33 of 44, by cyclone3d
Well, the power adapter arrived from ARSTech today.. and guess what?
It is the same exact brand and model I ordered from Mouser..... grrrrr.
On their site they say not to use a switching power adapter and then I order one of their "special" power adapters and it is the same exact thing I already have... and for about $30 more.
YMF7x4 Guide
Reply 34 of 44, by darry
cyclone3d wrote on 2020-09-17, 20:21:
That is worth a well-worded complaint, IMHO .
Reply 35 of 44, by cyclone3d
darry wrote on 2020-09-17, 20:24:
Here is what I sent them:
I have a couple usb2isa-x3 cards. I already had a power adapter on hand (Mean Well GP50A13D-R1B) and then saw in your FAQ sectio […]
I have a couple usb2isa-x3 cards. I already had a power adapter on hand (Mean Well GP50A13D-R1B) and then saw in your FAQ section where it says:
"- Can I use other external power supplies?
For testing purposes you may use one of our external supplies - isa-pwr-x2, isa-pwr-xr, isa-pwr-ec ."
So I went ahead and ordered an isa-pwr-x2 power adatper from you.
I received it today and, much to my surprise, it is a switching power supply which your FAQ says to not use. It is a Mean Well P50A13D-R1B, which from what I can find is just the older, discontinued, model of the power adapter I already have.
That and the fact that I spent a decent amount more to order the power adapter from you makes me not very happy.
Why are you selling switching power adapters when your FAQ states that they should not be used?
Now to see what they respond back with.
YMF7x4 Guide
Reply 36 of 44, by cyclone3d
And I just realized that I posted that in the completely wrong thread...
YMF7x4 Guide
Reply 37 of 44, by darry
cyclone3d wrote on 2020-09-18, 04:25:
🤣, and I answered without even noticing . Hopefully a mod/forum admin will make things right .
Reply 38 of 44, by Stiletto
And I just realized that I posted that in the complety wrong thread...
Once I figured out which thread you meant... moved posts to this thread. Annoying part: it happened on a page break, oof! 😁
do the Fandango!" - Queen
Stiletto
Reply 39 of 44, by digger
Jo22 wrote on 2020-08-31, 06:29:
Disney Sound Source likely will fail, since it is DMA-based.
Somewhat off-topic, but this is incorrect. The Disney Sound Source does not utilize DMA. It should work on any parallel port. The DSS predates the introduction of the ECP mode that added DMA support to parallel ports in later PCs in the Win9x/NT era.
It doesn't even use the IRQ line of the PC parallel port to signal that the FIFO buffer is full. The game or driver needs to poll pin 10 on the Sound Source to determine when it's okay to send data to it. See https://archive.org/details/dss-programmers-guide
So a DSS wouldn't even need a USB2ISA adapter to work (although it would likely work fine when paired with an ISA parallel port card plugged into the adapter). It should still work with any parallel port on a post-ISA PC, or even with a PCI/PCIe parallel port card, as long as the port is still accessible from DOS using the legacy I/O ports, such as 378h for LPT1, etc.
Much more interesting, as others here have already mentioned, would be to have a Sound Blaster compatible ISA card fully working with this adapter. And perhaps support for it could be added to QEMU as well.
