386 with VLB, suggestions?
Reply 20 of 28, by Deksor
@Bancho @kixs
I have added Bancho's photo to UH19 :http://www.win3x.org/uh19/motherboard/show/5531
Would you like to upload your bios (or at least a POST screen image), so I can identify the manufacturer (I suspect Dataexpert, but I need that for a confirmation)
@quicknick I added your image to the page because it's better 😀
Can you confirm that VLB doesn't work on your board ? I can add this statement, but a double check is better than just one ^^
Reply 21 of 28, by quicknick
@Deksor - thanks, kind of a cluttered background, learned to take better ones meanwhile 😀 . This one is resized 50%, can send you the full one if you want.
I confirm VLB does not work on either board, at least for VGAs - tried a bunch of them and no boot. The +5v and GND pins match VLB pinout, checked beforehand.
Would be great to solve the mystery of the unworkable VLB on these boards, maybe open up a separate thread about it?
Reply 22 of 28, by feipoa
If I recall right, a VLB card doesn’t help much on the PGA132 platform unless you are using a 486 CPU, like the DLC, DRx, or SXL. I have some benchmark results on Vogons but can’t find them at the moment. Best hybrid board I’ve come across was a Daewoo branded board based on, I think, the ALi M1429 chipset. That board even worked with an IBM BL3 interposer, but unfortunately the interposer blocks both VLB slots.
Reply 25 of 28, by Anonymous Coward
quicknick wrote on 2020-10-20, 18:09:
Got this board (a pair of them, actually) and the VLB slot doesn't work even with a 486 installed (haven't tried a 386 as it req […]
Got this board (a pair of them, actually) and the VLB slot doesn't work even with a 486 installed (haven't tried a 386 as it requires soldering a PQFP one which I don't have).
As a matter of fact, in the elhvb description it is stated that the VLB doesn't function. Strange board.
Looking at the photos above, I wonder if the 486 socket doubles as a 387 socket when there's a 386 soldered...
Maybe like the FX 3000 board, the slot isn't really VLB but another type of local bus.
Reply 26 of 28, by Bancho
Does anyone know if there is a Mr.Bios for these boards? I will fire mine up today and get the BIOS string. I will at some point try and dump the rom as well.
Reply 27 of 28, by root42
@QuickNick: Intriguing board. It even supports the 486SX QFP. I really wonder why they added the VLB slot if it's non functional. Can you probe some pins of the VLB to see if it provides VCC and maybe some signals?
YouTube and Bonus
Reply 28 of 28, by quicknick
The +5v and GND pins are where they should be, no magic smoke was released. Guess I could re-visit those boards, but I wouldn't know what other signals to look for. And I'll be on the lookout when PQFP 386/486 turn up on cpu-world.
