VXD-drivers for Audigy 2 (not ZS!!)
Reply 20 of 23, by DenkoRetro
Hi guys, It's working now!
I figured out the problem with the noise and crackling, and it got fixed by disabling USB 2.0-support in bios.
The sound works fine now in 98se and also playing Midi-files, but I can't get the sound and music to work in Duke Nukem 3D under 98SE.
When I choose General Midi it says: Could not detect Mpu-401.
When choosing SB it says the same but with the FM-chip..
It was the same before with the WDM-drivers.
In the device manager for sound all I have is:
Creative Audio Processor
MPU 401-Compatible
Gameport/joystick
Shouldn't the Audigy 2 work fine with DOS-games under Windows 98?
Reply 21 of 23, by DenkoRetro
Joseph_Joestar wrote on 2020-11-04, 18:52:
If you do a clean install of Windows and follow my guide, you should be able to install VXD drivers from the CD image linked in that thread, despite your card not being a ZS.
Hello,
Would this fix my problem I wrote above?
Kind regards!
Reply 22 of 23, by DenkoRetro
cyclone3d wrote on 2020-11-04, 19:19:
What are the specs of the rest of your system? […]
The crackling thing was pretty big back in the day though I never experienced it on any of my builds except one where it was cured by moving the card to another PCI slot.
Lowering the PCI latency setting in BIOS might help as well.
Creative blamed the motherboard and chipset makers and the motherboard and chipset makers blamed Creative.
Hello,
My setup is:
CPU: Pentium 4 1.7GHz (socket 478)
RAM: 512mb RAM
Motherboard: MEDION Md5000 (latest bios)
Graphics: Creative 3D Blaster TNT2 M64 (AGP)
Soundcard: Creative Sound Blaster Audigy 2 SB0350
HDD: Hitachi Deskstar 41 GB
Reply 23 of 23, by Joseph_Joestar
DenkoRetro wrote on 2020-11-04, 21:40:
Hello,
Kind regards!
Yes, you would get fully functional SB16 emulation as well as the ability to load soundfonts for General MIDI music in DOS games.
Just remember that a clean install of Win98SE is required in order for everything to work correctly.
