Reply 20 of 43, by Takedasun
Unreal 1152x864
The attachment Unreal_ch1_05.png is no longer available
The attachment Unreal_ch1_06.png is no longer available
Reply 21 of 43, by Takedasun
Unreal Tournament 99
Demo with a single bot
The attachment ut99_01.png is no longer available
The attachment ut99_02.png is no longer available
The attachment ut99_03.png is no longer available
The attachment ut99_04.png is no longer available
Reply 22 of 43, by Joseph_Joestar
Interesting. I wonder why the TNT2 PRO goes from 23 FPS at 32-bit color with 2.08 drivers to just 9 FPS with 3.68 drivers. That's a huge difference!
Reply 23 of 43, by Takedasun
Nvidia driver bugs
Reply 24 of 43, by Nemo1985
Or nvidia dirty tricks that have been disabled in the newer driver?
Reply 25 of 43, by Takedasun
Half-Life ver. 1.0.1.6
Direct3D
The attachment Half-Life_01.png is no longer available
The attachment Half-Life_02.png is no longer available
OpenGL
The attachment Half-Life_03.png is no longer available
The attachment Half-Life_04.png is no longer available
Reply 26 of 43, by Eep386
What's interesting is how well the supposedly vastly inferior S3 Savage4 Xtreme manages to hang in there, on this game. Sure it's noticeably slower under 32 bit color, but 16 bit color it's only a little bit slower than the better cards. Perhaps the S3 drivers are sensitive to the CPU and chipset combination used?
Reply 27 of 43, by BitWrangler
Well until you swap the CPU out for a K6-3+ 550 and it gets slow again.
Reply 28 of 43, by Caluser2000
I should imagine one that works would be go.....
Reply 29 of 43, by Eep386
BitWrangler wrote on 2021-08-05, 03:31:
Ought to be just fine for my Pentium MMX 233MHz system. (PCI version anyhow.)
Much as I love 3dfx cards, the prices are absoludicrous anymore.
Reply 30 of 43, by Takedasun
Need for Speed III: Hot Pursuit (Modern Patch for Need for Speed III) 1998.
Direct3D 5
The attachment nfs3_01.png is no longer available
The attachment nfs3_02.png is no longer available
Direct3D 6
The attachment nfs3_03.png is no longer available
The attachment nfs3_04.png is no longer available
Reply 31 of 43, by swaaye
NFS3 has Glide support and that is probably the fastest/smoothest option with a K6.
Reply 32 of 43, by Takedasun
Need For Speed 4: High Stakes
The attachment nfs4_01a.png is no longer available
The attachment nfs4_02a.png is no longer available
Reply 34 of 43, by BitWrangler
Kinda surprised how well the Rage 128 are doing, I don't feel so dumb for owning *cough* several now.
Reply 35 of 43, by Takedasun
Sphere478 wrote on 2023-07-24, 22:00:
Add a radeon 9800 pro to the tests if you are able to get one to run stable.
There is no way to test the Radeon 9800 right now.
Taking into account the weakness of the platform, most likely the performance will be equal to Radeon 9250 (Catalyst 4.7)
Reply 36 of 43, by Takedasun
Need For Speed 4: High Stakes. (1024x768x16)
The attachment S3_Savage4_nfs4_8.10.33_16-bit.png is no longer available
S3 Savage 4 Xtreme 166/166 Mhz (64-bit, 32MB, ver. 8.10.33)
The attachment S3_Savage4_nfs4_8.20.38_16-bit.png is no longer available
S3 Savage 4 Xtreme 166/166 Mhz (64-bit, 32MB, ver. 8.20.38)
The attachment S3_Savage4_nfs4_creative.png is no longer available
S3 Savage 4 Xtreme 166/166 Mhz (64-bit, 32MB, Creative Driver)
The attachment Nvidia_tnt2_nfs4_2.08.png is no longer available
Riva TNT2 (driver v2.08)
The attachment Voodoo3_NFS4.png is no longer available
Voodoo3
Reply 37 of 43, by Takedasun
Need For Speed 4: High Stakes (1024x768x32)
The attachment Ati Rage128_NFSHS_32-bit.png is no longer available
Ati Rage128
The attachment G400_NFSHS_32-bit.png is no longer available
Matrox G400
The attachment S3_Savage4_nfs4_8.10.33_32-bit.png is no longer available
S3 Savage4
The attachment Nvidia_tnt2_nfs4_2.08_32-bit.png is no longer available
Nvidia TNT2
The attachment GF3_NFSHS_32-bit.png is no longer available
Nvidia Geforce 3
Reply 38 of 43, by appiah4
There is a lot of inconsistency wrt the clouds being rendered between those cards as well as between driver versions for the S3 Savage 4.
Reply 39 of 43, by Takedasun
Millennium Soldier: Expendable (DirectX 6) 1999.
The attachment Расходный Материал_ch1_01.png is no longer available
The attachment Расходный Материал_ch1_02.png is no longer available
The attachment Расходный Материал_ch2_01.png is no longer available
The attachment Расходный Материал_ch2_02.png is no longer available
