Reply 20 of 35, by dr.zeissler
What is the trick to get Unreal working with the S3TC Textures on savage4?
I tested lot's of drivers and different Unreal Versions, nothing worked.
Some thing's I came across:
- The S3-Drivers that do not offer an installer sometimes lack the vgart.vxd so they cannot be installed. (you can copy the file from another driver)
- Some "Win9x" drivers require Win98. If you install them on Win95 you will get a vxd-exception right at the restart of win95
- Copying the (latest) "metal.dll" to the game directory is useless, it always uses the metal.dll in "windows/system".
- The latest metal.dll "2.0.3" seems to break metal with the win95-drivers. Unreal looks like "software-rendering" with these but UT99 does seem to care.
I managed to get UT99 working correct with a driver package from 1999. These drivers seem to be best on win95. Now I will test Win3x/OS2/Linux/Amithlon...
More to come...
...but still no "unreal" working with S3TC... because UT99 is working correct I thing the "unreal-engine-version" is the key here. S2MeTal seems to be on 2.2.4v upwards...but 2.2.4...2.2.6 does not change anything.
