I've organized the news of my "project" on the Spring Circle SF586 motherboard.
Today 2MB of cache arrived from China.
The attachment IMG_5180.jpeg is no longer available
The cache isn't 10ns, but 15ns. Chips are remarked but all are working.
It overclocks worse than my previous 512KB Winbond chips.
Well, trading speed for capacity and stability. Previous 512KB I had overclocked to 12.8ns but on the edge of stability (the floppy disk was already starting to fail). With this new cache, it only takes near 15ns but it's stable and faster overall.
CTCM's with 2MB of cache is driving me nuts - it says there's no L2 cache.
The attachment camphoto_684387517.jpeg is no longer available
And CACHECHK thinks it's 15ns RAM.
The attachment camphoto_1254324197.jpeg is no longer available
The new cache started at 10-11 ns. But the test hangs.
I read the chipset documentation, there's also a catch with cache interleaving.
Like, if you want higher speeds, set it to 1 MB; if you set it to 2 MB, it disables cache interleaving.
Okay, it's a little faster and more stable.
And my favorite section: "Turbo Mode Operation"
Motherboard can operate in the following modes:
1) mode with the Turbo button pressed (CPU at 100 MHz and everything at maximum settings) - speed is naturally equal to a P100 computer.
The attachment IMG_5181.jpeg is no longer available
2) mode with the Turbo button released (CPU at 50 MHz and everything slows down to 50 MHz, although it's slow, but the L1 and L2 caches are present) - speeds below 5x86 133 MHz and even below the Pentium 60 MHz
The attachment IMG_5185.jpeg is no longer available
Need help? Begin with photo and model of your hardware 😉
