Reply 20 of 22, by Horun
- l33t++
Yeah that is a very custom 15pin back panel part (remind me to never consider an Ipex case 🤣) . Have seen other cases with built in amp and speakers but the input is way more obvious and easier to adapt. One of my cases has amp+speakers but a true 1/8" stereo input jack on the back so you only need a short cable from sound card "line out" to the "amp in" connection., my other speakered case actually has a short 1' cable out the back with mini plug to directly plug into the sound card output.
Good luck !
