help autoexec
Reply 20 of 58, by weedeewee
scroeffie wrote on 2021-09-16, 12:33:
D: wont work
Please take a step back, and re-read the comments again.
You just added the line, which I told you it needed to be in config.sys, to autoexec.bat.
Do not ask Why !
Reply 21 of 58, by scroeffie
DEVICE=C:\DEV\MTMCDS.SYS /D:MSCD001
you mean this does it need to be both in config and auto i think i did
Reply 22 of 58, by Gmlb256
scroeffie wrote on 2021-09-16, 12:37:
Not in AUTOEXEC.BAT. 🤦
Reply 23 of 58, by weedeewee
The MTMCDS.SYS line needs to be in config.sys
the MSCDEX.EXE line in autoexec.bat
Do not ask Why !
Reply 24 of 58, by scroeffie
so i remove this line in the autoexec DEVICE=C:\DEV\MTMCDS.SYS /D:MSCD001
oke wil try
it says bad command line D: not working
Reply 25 of 58, by weedeewee
scroeffie wrote on 2021-09-16, 12:40:
oke wil try
you used the wrong path for mscdex.exe in autoexec.bat
Do not ask Why !
Reply 26 of 58, by scroeffie
You made an error in the config.sys by trying to do this :
DEVICEHIGH=C:\BIN\MSCDEX.EX /D:MSCD001 /M:10
it should be this :
DEVICE=C:\DEV\MTMCDS.SYS /D:MSCD001 <<< ? wrong or correct
Reply 28 of 58, by scroeffie
iam realy confused but wil try
oke its working now but what i dont understand is you guys told me the drivers are in the dev folder and not bin
so to me it makes sense to add them to the auto and the config files ?
but what is the bin folder ?
MSCDEX.EX < this file is not the mistumi driver or is it ?
what does the config program do load the drivers ?
and the autoexec ?
Reply 29 of 58, by Gmlb256
scroeffie wrote on 2021-09-16, 12:51:
This line actually should go away from CONFIG.SYS. 😦
Reply 30 of 58, by scroeffie
okay, will check
Reply 31 of 58, by weedeewee
Gmlb256 wrote on 2021-09-16, 13:00:
you're a bit late :-p
Do not ask Why !
Reply 32 of 58, by Gmlb256
weedeewee wrote on 2021-09-16, 13:01:
Seems to be unable to understand of what we're saying in this case, which is not even hard. 😜
Reply 33 of 58, by weedeewee
scroeffie wrote on 2021-09-16, 12:57:
oke its working now
GOOD !
The photos you posted show those files to be in those places.
That file does not even exist. at least it shouldn't. there's no reason to.
I can only guess you mistyped it at some point.
and the autoexec ?
to lessen the confusion, let's just say, Yes.
Do not ask Why !
Reply 34 of 58, by weedeewee
Gmlb256 wrote on 2021-09-16, 13:04:
Phil should have his own forum for this 🤣
Do not ask Why !
Reply 36 of 58, by weedeewee
scroeffie wrote on 2021-09-16, 13:10:
all i can say is thanks for helping me 😀 iam not so smart
https://www.youtube.com/watch?v=ERTQtfKFP08
Smart enough. Enjoy your day of the tentacle !
Do not ask Why !
Reply 38 of 58, by scroeffie
iam using 256mb now cfcard but iam going to upgrade to 4 gb because some games like full throttle are 1.3gb
can i make a back of the autoexec and config ? to store on my windows 10 pc
Reply 39 of 58, by Kcil
in the AUTOEXEC.BAT, delete C:\DEV\MTMCDS.SYS /D:MSCD001
and replace it with LH C:\BIN\MSCDEX.EXE /D:MSCD001 /M:10
