Newly made Retro styled AT/Baby AT Case
Reply 20 of 21, by kolmio
wbahnassi wrote on 2025-03-13, 01:56:
how compact those baby AT towers and desktops actually were.
That's because at 216 mm height, BabyAT is lower than microATX (which has 244 mm height), yet has 7 extension slots like Full ATX motherboard.
That's also why a combo BabyAT/microATX case can be constructed, given that rear side is modular/swappable. Which is unusual, because the rear side is always non-removable. So one needs to be inventive about how to get around that. If this issue is solved, such case can be commercially viable, I think.
Also, those cases width was limited to the height of expansion slot. Modern GPUs are often much taller than its mounting bracket. That's another problem.
Windows 95 | Chaintech 486SPM M102.A | AMD-X5-133ADW or Am486DX4-100 | 48MB SIMM FPM | ATI Rage 3D II+DVD | CT4100 | 8GB CF
Windows 98 | Acorp 6BX86 | Pentium III 900, slotket | 512MB PC100 | Radeon 9250 | SoundForte SF16-FMI-03 | 64GB MicroSD
Reply 21 of 21, by kolmio
Actually, in some cases e.g. InWin A500, motherboard mount panel slided out together with expansion slots. So one panel can be for AT and another for mATX.
The screenshot is from https://www.youtube.com/watch?v=FI21Pj0WPXI
