Reply 20 of 52, by pete8475
H3nrik V! wrote on 2021-10-27, 04:33:
So, a bit faster few places with 64 vs 128 megs? But as for what I can see, there is nothing being slower with 64 megs? It looks like then, that it might be that the L3 actually only can cache the first 64 megs ..
3dmark 99 scored highest in the CPU score section with 128MB and cache turned on.
This weekend I'm going to test out some other graphics cards that have VGA connections, I had this machine at my main desk which has a DVI/PS/2 KVM so I needed DVI for now. Ultimately I'll be using it with a Lenovo LCD screen that has both DVI and VGA.
EDIT - Added a pic of the screen I'm going to be using, it has a neat little set of speakers that attach to the bottom of the screen, they don't sound awesome but they are acceptable. I probably paid way too much to get those on ebay.
    62.22 KiB
Reply 21 of 52, by Jasin Natael
pete8475 wrote on 2021-10-27, 01:04:
Awesome! I'm sure it was the same guy if it was in the box, mine was too. […]
Brawndo wrote on 2021-10-26, 23:09:
Funny, I bought the same case on ebay, probably from the same seller. 🤣 I also paid more for the case than I probably should have, but how often are you going to find a NOS AT case? Mine is still in the box, no idea what I'm going to use it for yet. I have an ASUS TX-97 mobo laying around not currently in service, guess I'll use that.
Onto the 64meg benchmarks:
64MB with motherboard Cache On:
3dmark 99 - 1430 3dmarks, 4837 cpumarks
3dmark 2k - 805 3dmarks, 41 cpumarks
Quake 3 - 10.0 fps! TEN!
3dbench 1.0c - 348.3
Chris's 3d Benchmark - 466.8 (280.0 fps)
Chris's 3d Benchmark 640x480 - 103.1 (61.8 fps)
Quake timedemo - 66.6 fps
Landmark System Speed Test - 585 MHz AT with a 721 MHz 80287
Topbench - 282
64MB with motherboard Cache Off:
3dmark 99 - 1203 3dmarks, 4429 cpumarks
3dmark 2k - 625 3dmarks, 35 cpumarks
Quake 3 - 7.8 fps
3dbench 1.0c - 347.8
Chris's 3d Benchmark - 430.0 (258.0 fps)
Chris's 3d Benchmark 640x480 - 84.5 (50.7 fps)
Quake timedemo - 59.2 fps
Topbench - 279
EDIT - I bolded all the values that scored highest of all in this post, please keep in mind all tests were only run ONCE in each config though. Really good testing should be 3 or more runs and averaged but I just don't have time for that.
Made more a difference than I figured it would. Looks like motherboard cache on is better regardless. I have a K6-3+ build that I run 128mb of ram on a PC Chips M571, I also keep my cache enabled but hadn't done a ton of A/B testing.
Reply 22 of 52, by leonardo
Onto the 64meg benchmarks: […]
Your scores seem to be on the low side, although I can only compare the 3DMark2000 one. My similar system at 450MHz gets some ~1550 points currently, give or take. Are you running the benchmark in 32-bit color?
I know you have a K6-II+ - but I doubt the difference can be explained by the difference between that and a K6-III+. The Radeon 7000 should also be quite a bit faster than a Voodoo3.
[Install Win95 like you were born in 1985!] on systems like this or this.
Reply 23 of 52, by Jasin Natael
leonardo wrote on 2021-10-27, 18:36:
You got me to wondering, so I went back to my own thread where I had ran the same benchmarks and sure enough I was getting roughly 1500ish points in 3DMark 2K as well.
I've got a K6-3+ as well as a Voodoo 3 (PCI) but my board isn't very fancy and only runs at 83mhz FSB.
I would say he must be running it at 32bit color depth, otherwise that is some terrible performance for a Radeon 7000 and has to be down to driver overhead.
My results:
3DMark 99 Max Default Run 800x600 16bit:
2750 3D Marks
6501 CPU 3D Marks
3DMark 2000: Default Run 1024x768 16bit:
1509 3DMarks
Reply 24 of 52, by pete8475
I simply left it on the default settings, so presumably 32bit.
I'll boot it up and run 3dmark in both color depths to see what the performance difference is.
EDIT - It defaults to 1024x768 16 bit, running it now on that setting.
EDIT 2 - So after running 3dmark 2k on default this time it scored LOWER, 788 points. In 32bit there was almost no difference, 772 3dmarks.
    42.39 KiB
    42.38 KiB
Reply 25 of 52, by pete8475
Decided to test an MX4000 in this PC now that it's got a screen with VGA input (no DVI on this card).
3dmark 99 - 1881, 4931 cpumarks
3dmark 2k - 1508, 107 cpu 3dmarks (first run after installing this card got 1809, 119 cpu 3dmarks for some reason)
Reply 26 of 52, by Jasin Natael
pete8475 wrote on 2021-10-28, 00:03:
Dang. Is that Radeon a 32bit memory version or something weird?
It seems crazy to me that it is THAT much slower than the Geforce card.
Reply 27 of 52, by Gmlb256
Jasin Natael wrote on 2021-10-29, 17:13:
It uses a 64-bit memory interface like the GeForce MX4000. Seems to be related to 3DNow! optimizations which only nVidia and 3Dfx did bother to implement.
Reply 28 of 52, by pete8475
64 bit according to Everest.
Interestingly 3dmark 2001 reports it as being "software T&L" though, so perhaps it's a "budget" or crap version of the card.
    82.89 KiB
    88.23 KiB
    74.12 KiB
Reply 29 of 52, by Gmlb256
pete8475 wrote on 2021-10-30, 06:13:
The lack of hardware T&L can also affect negatively the performance if that's the case.
Reply 30 of 52, by pete8475
Gmlb256 wrote on 2021-10-30, 13:28:
That's exactly what I was thinking.
Looking at the wiki page on the 7000 series cards it would seem this is the "entry level" aka trash level card. https://en.wikipedia.org/wiki/Radeon_R100_series
Reply 31 of 52, by mastergamma12
The Radeon 7000 definitely lacks Hardware T&L, had one a long time and it was a slow card.
The Tuala-Bus (My 9x/Dos Rig) (Pentium III-S 1.4ghz, AWE64G+Audigy 2 ZS, Voodoo5 5500, Chieftec Dragon Rambus)
The Final Lan Party (My Windows Xp/7 rig) (Core i7 980x, GTX 480,DFI Lanparty UT X58-T3eH8,)
Re: Post your 'current' PC
Reply 32 of 52, by leonardo
...or my Voodoo3 for that matter. Then again the GeForce is currently tied with the V3, so probably that's about as much as you can squeeze out of any 3D-accelerator with these K6-II/K6-III CPUs? At least now he's got something on-par with what you'd.expect. Half the score of a V3 with a newer video card just seemed wrong.
Reply 33 of 52, by Jasin Natael
leonardo wrote on 2021-10-31, 21:37:
Yeah I can buy roughly the same speed as a V3 with that CPU, but half seems off. But looks like it is mystery solved.
Reply 34 of 52, by pete8475
So I've had an Asus TXP4 sitting around for a while now and decided why not compare the speed of these parts in that board vs. this one.
So I did some quick benchmarks after swapping over everything except the RAM. The RAM in the TXP4 is a single 256MB stick of PC100 CL2 Kingston memory.
Results:
VX97
Quake timedemo - 65.2 fps
Quake 3 (Radeon VE) - 10.0 fps
Topbench - 282
Speedsys 4.78 Processor Benchmark - 509.67
Speedsys 4.78 Memory Bandwidth - 119.87 MB/s
TXP4 256MB PC100 CL2 SDRAM
3dmark 99 - 2262, 5887 cpumarks
3dmark 2k - 1981, 133 cpumarks
Quake timedemo - 78.0 fps
Quake 3 (Radeon VE) - 12.2 fps
Quake 3 (MX4000) - 27.8 fps
Topbench - 304 (451 was incorrect and is generated when restarting into DOS from 98)
3dbench 1.0c - 241.8
Chris's 3d Benchmark 478.8 - (278.3 fps)
Chris's 3d Benchmark 640x480 106.1 - (63.6 fps)
Speedsys 4.78 Processor Benchmark - 516.76
Speedsys 4.78 Memory Bandwidth - 218.23 MB/s
Almost across the board graphics and processor improvements in these tests. That 3dbench program reports a lower number for some reason though.
I've also ordered an MX4000 with DVI from ebay, presumably otherwise it's the same as the current one.
EDIT - Eventually I am going to try single sticks of 64mb and 128MB SD and the EDO memory from the VX97.
EDIT 2 - I was also hoping some of the PCI cards (various USB 2 cards, several ATI and Matrox graphics cards) I have that don't work in the VX97 would work in this board but none do.
Reply 35 of 52, by pete8475
Trying to find my bag of small sdram modules right now and not having much luck so far, but when I do I'll do some 64mb testing.
EDIT - Memory found, running some benchmarks now.
TXP4 64MB PC100 CL2 SDRAM
3dmark 99 - 2356, 5952 cpumarks - higher than 256
3dmark 2k - 2200, 144 cpumarks - also higher than 256
Quake timedemo - 76.8 fps
Topbench - 304
3dbench 1.0c - 241.5
Chris's 3d Benchmark - 479.9 (287.9 fps)
Chris's 3d Benchmark 640x480 - 106.1 (63.6 fps)
TXP4 128MB PC100 CL2 SDRAM
3dmark 99 - 2315, 5961 cpumarks
3dmark 2k - 2150, 141 cpumarks
Quake timedemo - 77.5 fps
Topbench - 304
3dbench 1.0c - 241.6
EDIT 2 - I figured out what's up with that high Topbench score on my 256MB original run, if I boot into Windows 98 and then restart in MS-DOS mode it gives a score of 451 regardless of what ram is in the system. If I boot straight to DOS it gives the lower and probably more accurate numbers.
EDIT 3 - It seems to me that 128MB of CL2 SD-RAM is the optimal config, at least for the hardware I have so I'm going to go with that.
Reply 36 of 52, by Sphere478
pete8475 wrote on 2021-10-26, 05:05:
Running Some benchmarks: […]
MB Cache On:
3dmark 99 - 1388 3dmarks, 4906 cpumarks
3dmark 2k - 805 3dmarks, 42 cpumarks
Quake 3 - 9.8 fps
Topbench - 282
Speedsys 4.78 (don't know what I'm looking for in here tbh):
MB Cache Off:
3dmark 99 - 1230 3dmarks, 4403 cpumarks
3dmark 2k - 631 3dmarks, 35 cpumarks
Quake 3 - 8.1 fps
Chris's 3d Benchmark - 430.1 (258.0 fps)
Chris's 3d Benchmark 640x480 - 84.4 (50.6 fps)
Topbench - 279
EDIT - So this is just 20 or 30 minutes or so of playing around with becnhmarks and I think it's safe to conclude that in this case motherboard cache turned on is much faster. Also if there's any specific test you want me to do please let me know and I'll run it!
Interesting how on some mobos it’s faster off and some it’s faster on. So best for everyone to try it both ways and see.
Sphere's PCB projects.
Reply 37 of 52, by Jasin Natael
pete8475 wrote on 2021-11-13, 23:53:
So I've had an Asus TXP4 sitting around for a while now and decided why not compare the speed of these parts in that board vs. t […]
Results:
VX97
Topbench - 282
That memory bandwidth increase is massive.
Reply 38 of 52, by Gmlb256
Jasin Natael wrote on 2021-11-15, 16:34:
Results:
VX97
Topbench - 282
Indeed, however I get 175.57 MB/s for the memory bandwidth in SpeedSys using the exact same CPU with just EDO RAM (still lower than the ASUS TXP4 using SDRAM though). I think that the EDO RAM used on the ASUS VX97 may not handle the optimal memory configuration with 75MHz FSB set.
Reply 39 of 52, by Jasin Natael
Gmlb256 wrote on 2021-11-15, 17:06:
Very likely.
My humble little PC Chips m571 with the SiS 5598 doesn't do that well even with the 83mhz FSB it runs at.
Superscape 1.0 Low Res:
Superscape 1.0 High Res: 587.5
Chris' 3D Bench Low Res: 627.6 (376.5FPS)
Chris' 3D Bench High Res: 116 (69.6FPS)
PC Player Bench Low Res: 162.3FPS
PC Player Bench High Res: 41.2FPS
DOOM Minimum: 2134 in 140 realtics
DOOM Maximum: 2134 in 510 realtics
Quake Low Res: 88.5
Quake Medium Res: 38.0
Quake High Res: 22.2FPS
Topbench: 519
Speedsys CPU: 564.46
Speedsys Memory Bandwidth - 186.69 MB/s
Speedsys Throughput - 122.57MB/s
