Reply 20 of 25, by maxtherabbit
- l33t
weedeewee wrote on 2021-12-13, 18:51:yeah, you could do that. You just need to wire it up with the same wires swapped as the cable is for the 5.25 connector. Also y […]
Sucho wrote on 2021-12-13, 18:45:It seems to me that drive sel for A: and B: are specific pins on the connector. Maybe I could use something like these to swap t […]
It seems to me that drive sel for A: and B: are specific pins on the connector. Maybe I could use something like these to swap those pins in between I/O card and cable itself?
Also you can hook it up but you will again have to leave the 5.25 drive off of the cable.are you sure you don't have jumpers on your 3.5 floppy drive ?
You can't use jumpers to change the drive letter on a PC-std shugart setup. Even if you change the DS jumpers appropriately, the motor on signals will still be decided by the cable because the PC FDC has two separate motor on signals
