Manhattanman wrote on 2022-01-31, 00:55:
Is that 3-cell battery the CMOS battery? If not, what does it power? If it's removed, I assuming it needs replacement. Correct?
I've located a source for this battery.
One other question: If the CMOS battery is bad, going bad or dead, why, immediately after starting the machine did it display the correct date? Very strange. This computer probably hasn't been run in at least 10 years.
The 3-cell battery is what IBM calls a "resume battery"; when putting the laptop to hibernation, it would provide power to the (i think) memory to hold the system snapshot, and would keep date and time. Possibly some other stuff. Made to be rechargeable so that users wouldn't have to replace it, and it's a 3 cell so it holds more juice (a regular CR2032/CR1220 would be drained in a short amount of time).
They're nickel-metal hydride, just like those old "barrel" batteries found on older mobos and some Amigas. All my Thinkpads that had this battery (3x760, 755CX) had those batteries already leaked.
The attachment Battery.png is no longer available
In 760s they would damage the right speaker, the keyboard, and TrackPoint, whereas in the 755CX it damages the front I/R cable and could spread down to the system board, where onboard memory and other stuff lies. Here's the damage in my 755CX:
The attachment Battery 2.png is no longer available
The attachment Battery 3.png is no longer available
As for the CMOS battery, if it were totally dead, it would complain about 161 and 163 errors, preventing you from booting altogether. Could be that it is on its last legs but still has some juice, and perhaps that Direct Access shell has some function to maintain the date & time and updated it using some point of reference. OR, the date and time was set wrong and Direct Access tries to change the date on its own to have some sort of continuity between the file timestamps?
Other explanations: ghosts, or esoterica. Just thinking out loud here. You could use a multimeter to check the CMOS battery's voltage; that should give you an idea if it's dead or not.
