386 / 486 Build: Your Suggestions Please?
Reply 20 of 33, by AlexZ
Definitely go for it. It's a 5x86 133Mhz with PCI and 72pin SIMM memory. The best 486 there is.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 21 of 33, by CoffeeOne
C0deHunter wrote on 2022-04-02, 05:34:
I see, thanks for clarification! I am going to get it then, the best part is the price: $50 😀
Hello,
When you want to use a DX33, I would suggest, that you also remove the cache module. Otherwise it might be too fast.
Reply 23 of 33, by C0deHunter
I know! I got it, and after Changing 7 jumper settings, was able to install my 486DX-33:
33Mhz speed finally baby!
Now to test Turrican II, Wing Commander, and Tyrian!
PIII-800E | Abit BH-6 | GeForce FX 5200 | 64MB SD-RAM PC100 | AWE64 Gold | Sound Canvas 55 MKII | SoftMPU | 16GBGB Transcend CF as C:\ and 64GB Transcend CF D:\ (Games) | OS: MS-DOS 7.1-Win98SE-WinME-Win2K Pro (multi-OS menu Using System Commander 2K)
Reply 24 of 33, by imi
I wouldn't "waste" that nice board on a 33 though ^^
Reply 25 of 33, by eightbit
Consider yourself lucky you "missed out" on that first motherboard from your introductory post. I feel sorry for the sap who won that thing....hope it didn't sell for more than $10. My God...
And, congrats on the find. Very nice!
And changing the CPU that is in there with a 486-33? I should smack your hand for doing such a thing! 😉
Reply 26 of 33, by AlexZ
Isn't turbo button sufficient to slow down 5x86 133? Or combination of turbo button and 25Mhz FSB (= 100 Mhz) ?
Reply 27 of 33, by C0deHunter
eightbit wrote on 2022-04-04, 05:02:
I know! But believe me, I have *too many* Pentium 70, 90, 200 systems, I just needed a system so I could play older DOS games *without* constantly using SetMUL to disable L1 / L2 cache!
My DX-33 seems to play these games like a champ! Turrican II finally!
Quick Questions:
1) Another close by shop called and seem to have an Abit AB-PB4 in good shape. Should I get that and replace my existing motherboard? (PCChips M919 VER 3.3B/F, also know as Amptron DX-9700)
2) What would this Abit board offer over my current motherboard?
Thanks!
Reply 28 of 33, by AlexZ
C0deHunter wrote on 2022-04-05, 21:59:
If it's cheap then go and get it. Having a replacement board is useful in case you run into instability issues and need to troubleshoot it.
Reply 29 of 33, by imi
you have all the luck huh?
that's another great board, if it's cheap you should get it :p
but it's also another late 486 board that's really suited well to faster CPUs rather than a DX33 system.
Reply 30 of 33, by C0deHunter
Now a quick question about the Hard Drive LED activity:
When I connect my case's Hdd LED connector, it is *always* solid red (no flashing, indicating hard drive activity that is).
When I reverse this connector and connect the opposite way, the case LED is OFF.
Any ideas how to fix it?
And while I am at it, do you know how to change the turbo speed LED indicator on the case? At the moment I am reading 22, but I need to change it to 33 of course! (I am not using a Turbo switch, or case connector for it), I just want it to always display 33!
Reply 31 of 33, by chinny22
For the LED indicator just mess around with the jumpers on the back of the display till you get the reading your after, doing this with it turned on wont hurt anything and as no standard exists for how to configure these things trial and error is the best way.
Not sure about the HDD led, I've also got a PC that does this but didn't notice till it was all put back together and plugged in so just left as is, at least I know i have a HDD I suppose 😀
Reply 32 of 33, by C0deHunter
UPDATE:
When I install either of the SB16 (CT2900) or AWE64 (CT4500) I get crackled speech (digitized sound). Both cards are fine when utilizing music (AW64 Midi sounds normal)
I know both of them are OK, as I have used them many times in my other systems (P-90MHz, 233AMD, etc.)
I have 2 other (PCI based however) sound cards: SBLive! and Yamaha (YMF724F-V), that I can test out on this machine, but they are not *period correct*, and I was hoping I could use either of my SB16 or AWE64 instead.
Do you know why I get this crackling sound? Is it my CPU?
Thank you for your kind comments and help in advance.
Reply 33 of 33, by SpocksBeer
ISA bus speed too fast perhaps? You'll need to check BIOS for the current multiplier settings
