[Slot1 Mobo] Repair or Trash ?
Reply 20 of 22, by paradigital
NyLan wrote on 2022-06-25, 22:26:
soldering caps is ok, SMD can be tricky at some point
Soldering SMD isn’t too difficult, either with hot air or the slide-in method with a decent iron. Biggest issue with hot air is protecting heat sensitive stuff around the area (like the slots).
I’m not likely to be recapping mine, I only bought the PC for the case, I don’t want or need the internals!
Reply 21 of 22, by NyLan
Posting BIOS Just in case someone needs them
MS-6190-1.6.BIN : Original Bios I had. version 1.6
MEDION 9901 VER1 (MS-6190, Intel)_1.84.bin : Last official Bios
w6190zmx.bin : Last official Bios Patched for 128GB HDD
Successfully tested the patched Bios with a SSD limited to 250000000 LBA ( 128GB ) with Seatools for Dos
    Medion 9901.zip
    521.55 KiB
    25 downloads
My Intel SE440BX-2 Intel's website Mirror : Modified to include docs, refs and BIOSes.
Proud owner of a TL866 II
Personal GitHub
