Reply 20 of 35, by tsalat
weedeewee wrote on 2022-11-02, 19:48:The pin where you're measuring 2MHz seems to be A6 signal, not CLK signal. I think the correct pin to measure should be from th […]
tsalat wrote on 2022-11-02, 18:53:thank you again for your reply. I have measured today the CLK with the oscilloscope and I am bit confused. I have tried the posi […]
rasz_pl wrote on 2022-10-31, 20:00:some kind of resistor network should be pulling all data and 0-23 address bits high, while 24-31 low. ISA IRQs high, ISA DRQs low. D/C R/W M/IO high
is your bios/isa bus behind 245 buffer? even without bios that working pullups should never allow for any random behavior.thank you again for your reply.
I have measured today the CLK with the oscilloscope and I am bit confused. I have tried the position on the PGA socket to measure the CLK and as well the 15-pin on the QFP. Both were showing something like 2MHz and the signal was not looking as I would expect. I have uploaded a picture of the board here: https://www.sylex.repository.3d-sphere.com/in … d4pSdMLtfFHM4jX, and highlighted the points as well.Underneath the BIOS is an SN74LS244N BUFFER - I guess you were referring to this one.
I guess the CPU should have the 40MHz clock, right? or not?The pin where you're measuring 2MHz seems to be A6 signal, not CLK signal.
I think the correct pin to measure should be from the left bottom corner of the 386 footprint on the photo, the third column, 6th row, counting from the bottom left corner.
QFP pin 15 should be correct CLK signal. please verify, on photo, you measure left side of qfp package, 15th pin from top.
Hi and thank you for your answer,
I have measured the pins once more and the one you were referring as well: https://www.sylex.repository.3d-sphere.com/in … a3ZSyoHAKraX9KJ
i have included the pictures from the oscilloscope as well. The one on the PGA package, 6th row/3rd column, showed 80MHz. The one on the QFP, 15th pin, showed from 0,2-2MHz - was changing over time. If the debug card had indicated some communication, the frequency was higher but I have picked up maximum of 2MHz - see the picture.
Now I am not sure if the CPU is ok, I had the impression that the CPU should have 40MHz at this pin after it will be initialized but it doesnt look like this.
Could the CPU be damage, although it is a new one and the behaviour is more or less the same as with the old one?
thx, tomas
