PC Chips 754LMR+
Reply 20 of 64, by Nexxen
Nemo1985 wrote on 2022-10-15, 19:06:
Did you install the driver?
The integrated video card is a tnt2 and should work fine with 3dmark99
Installed the latest from nvidia, 71.84.
Win98SE fresh install, no other stuff except USB flash drivers driver 😀
Ok, it needs 6.1 to work.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Bare metal ist krieg.
Reply 21 of 64, by Nemo1985
I'd suggest to try something older then:
detonator_3_w9x-805 or nvidia_9x_5.32
I checked the inf files bot supports the Aladdin TNT2
Reply 22 of 64, by Nexxen
Nemo1985 wrote on 2022-10-15, 19:26:
I'm trying different shared sized (frame buffer); from 32 downward
Installed DX7
Now starts.
Guess results will suck a$$.
Reply 23 of 64, by Nexxen
I had to uncheck the first two tests, the rest is just displaying garbage on the screen, but it does something.
From time to time it shows % bar.
Reply 24 of 64, by Nexxen
You were absolutely right!
I used ver 6.18 as I couldn't locate 5.32's agp166 file in dirver archive (got from phil's).
Now it works. Gonna do the whole test batch.
Reply 25 of 64, by Nemo1985
great news! Glad it helped
Reply 26 of 64, by Nexxen
Screen 800x600, 1024x780, 1280x1024, 1600x1200
16+32 bit colours
I thought much worse.
Now I have something to compare to if the dedicated ram works.
Reply 27 of 64, by Nexxen
I made a mistake.
The motherboard has 43 pins per side for the SDRAM chips.
Ram sticks have like 28.
I need to locate specific sdram chips. I don't know if this operation is ever gonna see the light of day.
Could it be L2/3 cache?
ARchive has 3DMark 99 files in its extension, .3dp
Reply 28 of 64, by Nexxen
Do video cards have these on? I could desolder some.
Until tomorrow, I'm going to bed.
Reply 29 of 64, by Nemo1985
I can't help you with that, we need to wait someone who is more into this stuff (Tiido?).
Please take some cpu memory benchmarks too.
Reply 30 of 64, by Nexxen
Nemo1985 wrote on 2022-10-16, 00:14:
OK
How do I do that?
Reply 31 of 64, by majestyk
The typical RAM chips on (168-pin) SD-RAM sticks are 54-pin.
There are also SD-RAM chips with 86 pins (TSOP-II) like this one (it´s 4M x 32 = 128 Mbit = 16 MByte).
https://twen.rs-online.com/web/p/sdram/8115141
All 8 MB chips I found on the RS site are 54 pin.
Reply 33 of 64, by majestyk
Ydee wrote on 2022-10-16, 08:07:
Nexxen wrote on 2022-10-15, 23:19:
It is TSOP2 package 86pin, like this: https://www.issi.com/WW/pdf/42-45S32200L.pdf
The datasheet is from 2019 so those should still be available.
https://www.digikey.de/de/products/filter/spe … 46Ldl0i8BI8RKtA
(These are all 2M x 32)
Reply 34 of 64, by Nexxen
https://www.digikey.de/en/products/detail/iss … 00L-7TL/4733121
Low cost, in stock.
If you all have nothing to say against it I'll buy those.
Reply 35 of 64, by Nexxen
Total cost is around 40€, chips + shipping.
Beyond my budget for this board.
I'll look elsewhere, I'll shelf this for the time being. I'll run other suggested benchmarks.
I'll try to repeat less "I'll".
Reply 36 of 64, by Nexxen
Found this on a ATI RAge128 32MB ram, 4 chips.
Could fit?
Winbond
030WH
W986432AH-7
Specs say it's a 143mhz piece, 7ns. More than enough I believe.
Reply 37 of 64, by majestyk
These are looking good, I would give it a try.
Reply 38 of 64, by Nexxen
majestyk wrote on 2022-10-16, 11:42:
VCC is correct at 3.33V, looks like there is continuity with some traces up to the gx chip.
I couldn't find a test to get bandwidth values but it'll show up in 3Dmarks with fps.
With 32mb shared, only 24 show as usable. Prolly 24 + 8 like Voodoo, different uses?
C u l8r ppl!
