Reply 20 of 23, by Tiido
- l33t
The ROM should be cold and not even warm, so it seems the problem is found. It likely has a dead IO driver and that makes one signal stuck and that ends up corrupting everything on the sample bus and explains why things don't work out.
I have a spare chip somewhere, if I can find it, it can be sent your way since it will just continue to collect dust 🤣. (I moved recently to Norway and much of my stuff is still packed).
