Absolute fastest storage solution for socket 7
Reply 20 of 24, by Horun
Sphere478 wrote on 2022-12-05, 06:48:
Thanks 😀
Any ideas why our transfer speeds look so different? Because of driver? Seems weird that it isn’t a nice parabola like repoman’s
Oldest OS driver I found was for Win2000..... so close but yet so far 😁
added:
; ARC1160.INF - (Windows 2000 and above only)
; This is the INF file for Windows 2000 and above for the ARECA ARC1160 based
; SATA PCI RAID HOST Adapter SCSI Cards (ARC1160 80331)
Makes me wonder IF there might have been a Win98 or WinME driver at some point....
Reply 21 of 24, by Repo Man11
I tried my Promise S150 TX2 in the TXP4. The performance was close enough that I put the Sil3114 SATA back in - this is one of the two motherboards I have that the Sil3114 will work properly with, while the S150 has been less picky about what motherboard I use it in. The Sil3114 has a slight edge in read speed while the S150 is significantly better when it comes to write speed.
Reply 22 of 24, by Sphere478
Think it’s your fsb that is giving you the edge? Can you try k6-3+ 66x6? On a 430hx so I can compare to my tyan. If still faster, then it prob is driver
Sphere's PCB projects.
Reply 23 of 24, by Repo Man11
Okay. This is with the Sil3114 and a Crucial BX 120 gig SSD.
Reply 24 of 24, by Sphere478
🧐 okay so that does have something to do with it. It seems we have similar peaks but you have much more area under the curve. Driver?
