Reply 20 of 64, by Syntho
I've got parts on the way. Will update the thread when I try. Thanks everyone.
maxtherabbit wrote on 2023-01-22, 14:37:Syntho wrote on 2023-01-22, 10:09:I'll try a new chip. I was curious as to why the bios settings save fine, and reading.writing the entire EEPROM was fine too, but only the ESCD gives me an issue.
If it turns out to be the RTC chip, I'm looking at $30 for a new one. And replacing it is a gamble since I'm not sure that's what the problem is. It would be maybe better to just buy an entirely new motherboard...
PS: I just pulled all 9 cache chips from the board and it has no effect.
BIOS settings are written to RAM in the RTC module. ESCD is written to ROM in the flash IC. Totally different.
Replace your flash ROM
Not always. https://forum.vcfed.org/index.php?threads/how … s-option.50405/
The Winbond W29EE011-15 is not a "block" type eeprom like the Intels or MX28F1000 are "block" types so it may or may not be in the eeprom.
Usually it goes to eeprom if a block type, or goes to segment in RTC if not, but am sure there are exceptions and maybe why no BIOS update ever found (even wayback machine had none)..
Try disabling system bios cachable and playing with advanced settings in advanced menu. I had this issue which I recall being caused by one of the advanced settings but it was a long time ago
I tried disabling that very option but it had no effect.
Horun wrote on 2023-01-22, 15:55:
Interesting. From the VCFED thread that sounds like it may just be a Phoenix affectation. I've never owned a post-486 board with a Phoenix BIOS so that would explain why I've never encountered storing ESCD in the NVRAM
Programmed the NoS EEPROM. Popped it in. Same problem.
What now?
This thread details an ESCD issue with a PCChips M507: Re: PC Chips BIOS upgrade
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
Ordered the same chips for solving problem with my abit AB-PT5 rev 2.11
How do I know the chip in that thread (AT29C010) will work on my board?
I thought that a new Winbond chip would fix it since people said the old one was probably worn out. I don't see how get another chip would for the issue seeing as I've got a new one in there, but I'm willing to try I guess. Just don't know which suitable replacement to get.
Just an idea, maybe you already did it the "right" way, but don't just copy the old chip, use instead a clean image downloaded from the net. I once had a board that got stuck at "Verifying DMI data pool..." because of a flash chip gone bad, and a 1:1 copy on a fresh chip behaved exactly the same. Downloading the latest bios found on the net solved the issue.
quicknick wrote on 2023-01-27, 11:07:Just an idea, maybe you already did it the "right" way, but don't just copy the old chip, use instead a clean image downloaded from the net. I once had a board that got stuck at "Verifying DMI data pool..." because of a flash chip gone bad, and a 1:1 copy on a fresh chip behaved exactly the same. Downloading the latest bios found on the net solved the issue.
There is no bios available on the net unfortunately 🙁
Here's my board:
https://theretroweb.com/motherboards/s/azza-5is
So I'm guessing there's not much I can do at this point. I might just have to buy a new one.
You can try a BIOS from another mainboard that has the Intel FX chipset and the SMC super-I/O chip. Chances are good you find one that´s working, all mainboard manufacturers were producing FX mainboards .
Start with filtering Intel + 430FX + socket 7 / socket 5 in retroweb:
https://theretroweb.com/motherboards/?showIma … 74&cpuSocket1=4
https://theretroweb.com/motherboards/?showIma … 74&cpuSocket1=3
Now pick those with SMC super-I/O and 48-pin keyboard controller and start testing. Abit and Biostar look promising...
This here page says 5IS v3.x is the same as 5IW v1.x?
(It's stated in the manual title, see the "Downloads" tab).
So that's the same model that you have, but a different revision (and a different BIOS id).
Meaning there's bound to be some hw differences between them, but who knows what they are exactly.
Btw there's also some mobos that have the same BIOS id as yours, such as this Jamicon board.
But the date is different and also it's Award v4.51PG, unlike yours.
mr.cat wrote on 2023-01-28, 00:11:This here page says 5IS v3.x is the same as 5IW v1.x? (It's stated in the manual title, see the "Downloads" tab). […]
(It's stated in the manual title, see the "Downloads" tab).So that's the same model that you have, but a different revision (and a different BIOS id).
Meaning there's bound to be some hw differences between them, but who knows what they are exactly.Btw there's also some mobos that have the same BIOS id as yours, such as this Jamicon board.
Good point. That board has the Winbond I/O not the SMC like the AZZA. But the idea of the Award bios is very good.
I think the Abit AB-PT5 which has same SMC I/O and VIA KB controller and Award BIOS as the Azza board that Majestyk hinted too may be a good try for an alternate BIOS to test.
Ohh and just a reminder: those 82C42 KB bios are 40 pin in the DIP configuration 😀
Did you also found this one:
https://www.elhvb.com/mobokive/archive/azza/m … ual/5iw/5iw.pdf
The Abit AB-PT5 works. It updates the ESCD and starts booting. I noticed that it updates every time I restart, though.
I guess now I can pinpoint that the bios was corrupted somehow. I'd like to find the original bios somehow and get it back 100% but I don't think it'll be possible unless I find the exact board on eBay.
Syntho wrote on 2023-01-28, 11:19:The Abit AB-PT5 works. It updates the ESCD and starts booting. I noticed that it updates every time I restart, though.
Does it print "Updating ESCD... Success" or just "Updating ESCD..." on every boot? If the latter, it's not actually updating it
maxtherabbit wrote on 2023-01-28, 14:58:Syntho wrote on 2023-01-28, 11:19:The Abit AB-PT5 works. It updates the ESCD and starts booting. I noticed that it updates every time I restart, though.
Without "Success".
Guys, I've been fooling with this thing for too long now. The bios is nowhere to be found. I can get it to boot using another bios but pffft. I'm just gonna accept defeat and buy a new motherboard.
