Reply 20 of 22, by Anapan
Here's an elegant solution to the problem: emulate F-Prot Antivirus in dosbox and have it scan the suspect files. It was arguably the best dos virus scanner and went freeware after windows became standard. IIRC F-Prot even healed the programs most of the time because back then the viruses simply appended themselves to the end of the executable and placed a pointer to the propagation code. I used to spend hours looking through it's well commented virus encyclopedia explaining the virus naming origins and infection methods for all the viruses it knew of.
You could also upload the suspect file to Jotti Malware scan and see what a bunch of virus scanners have to say about it. One scanner may not give you a good idea about if a file is safe or not, but 25 of the best should be pretty conclusive (with an occasional false positive to keep things interesting).
Reply 21 of 22, by coolhaken
If someone viewed this thread then makes new virus,
DOSBox may have backdoor too ...
everything may un-safe ... 😢
Reply 22 of 22, by bloodbat
MS software, along with Adobe's and several other widespread programs already have enough...I wouldn't worry too much 😜
EVERYTHING is unsafe 😜
The very act of connecting to the net without a firewall is unsafe.
The web is unsafe...
