Unhappy Shuttle AI61 Slot A mainboard
Reply 20 of 25, by Minutemanqvs
...and I just add the latest available BIOS (AI61S022.ROM) in a binary format as an attachment in case someone stumbles on this post, instead of the auto-installing .exe file which updates your bios without any warning once you run it.
Searching anything Nexgen, PM me if you have one. Also ATI Rage 128 PCI cards.
Reply 21 of 25, by Tomek TRV
I have the same motherboard and it won't start. I am working far from home so I don't have much time to do something but there is one thing that interests me: under processor there should be temperature sensor and I see on photos that it looks like about 5 cm tape but on my motherboard it is cutted and only 0,5 - 1 cm left. The question is: will it run without this sensor? When I will come back to home I will finish recap, program new BIOS chip but I would like to know how it is with this temperature sensor.
Reply 22 of 25, by Minutemanqvs
It should run without the sensor I guess, you'll just have to disable temperature monitoring in the BIOS.
Reply 23 of 25, by Tomek TRV
So now I found some time to come back to this mainboard. It is not posting. I replaced all suspected capacitors, checked MOSFETs (4 close to processor), replaced BIOS chip and still no POST. I found that chip U2 on the left side of memory slots is getting very hot, I can't touch it. Symbols on it:
ICS 9179CF-06
9945
CA930565
I cant find any informations (datasheet) about this chip. Maybe somebody can tell me what is this and give some link to datasheet?
Reply 25 of 25, by Tomek TRV
Thank You very much. Now I have to find this part but I see that it will not be easy. Propably I will have to take it from other damaged motherboard.
