Reply 20 of 139, by JK1974
I made a video that shows how I use it - and the problems described above, including the mentioned "clicks" that I get instead of the real sound: https://youtu.be/4SMRV_loNSQ
First, I start the editor and try to play something, but you just hear this "click". Then I start the Munt panel - I initially just wanted to use it to see what´s going on with the virtual MT-32 or get a clue why it is not working; so, in fact, I don´t need the Munt panel itself. In the second part, I first start the Munt panel and then the MT-32 editor. In the last part, I load the Willy Beamish syx into the MT-32 editor (Munt panel not running), but here also just a clicking sound. In the end, I forgot to demonstrate playing the MT-32 sound with the Munt panel, so it should not be a Munt installation problem, but just believe me, that it works 😉
