Reply 20 of 21, by Sphere478
schmatzler wrote on 2023-05-17, 19:26:
I've now received an old ball mouse that works fine on all my computers with PS/2 ports. On this Asus board, the machine still h […]
On this Asus board, the machine still hangs when I move it around.
I guess I need to give up at this point. Something on this board must be broken, maybe it's the AMIKEY chip or something else.
If I ever get back to this I will update this thread, but for now I'll shove this into my cupboard and not think about it for a while. 😁
At least I got a nice old IBM mouse and a few PCI graphics cards out of this whole endeavour! 👌
You could trick yourself into believing you fixed the ps/2 port by wiring it into the usb header. If the mouse supports usb and ps/2 then it will work.
Re: Adding more usb ports to old motherboards without using a card
Sphere's PCB projects.
Reply 21 of 21, by Windows9566
i need to test the GPU compatibility on my MSI MS-5124, it also has a SiS 5511 chipset but is a different brand board.
Toshiba Satellite 200CDS
Toshiba Satellite Pro 430CDT
Toshiba Satellite Pro 480CDT
Toshiba Tecra 740CDT
IBM Thinkpad 760LD
Nan Tan(Clev0) FMA86T
