Reply 20 of 28, by wierd_w
If you do that, windows wont start. 😜
It will throw an error about not being able to enter protected mode due to conventional memory backfill.
Reply 21 of 28, by Gmlb256
Another suggestion: replace DOS=HIGH,UMB,AUTO with DOS=HIGH,UMB,NOAUTO.
This would avoid loading IFSHLP.SYS automatically and save some memory unless you want to start Windows 98 as intended.
Reply 22 of 28, by Disruptor
Personally I prefer systems where I could do I=C800-F7FF
Reply 23 of 28, by Gmlb256
Disruptor wrote on 2023-08-01, 14:03:
That would mean using a video card that has a smaller VBIOS ROM. 😉
Reply 24 of 28, by Disruptor
No problem for my ET4000/W32 VLB.
Reply 26 of 28, by wierd_w
This is win98, so...
Suitable USB wifi dongle* + the trial version of odyssey client. +
Sorry, not providing links. Funk software's library is still copyrighted and still buyable. However, the trial version can still be found, and will work for 30 days. Universal WiFi chip manager, with WPA2 support. Does NOT need the server.
Sagem XG-760N
Sagem XG-760A
NetGear WG111v2
et al
Alternatively, a LapLink cable/null modem cable, and either ctty from dos, LapLink, or FastLynx.
More alternatively:
Install the USBSUP package, and enjoy the benefits of USB Mass storage support, and just use a USB thumb stick.
Reply 27 of 28, by Azarien
Gmlb256 wrote on 2023-08-01, 12:36:
This is why for best results one should have a [MENU] section in config.sys, with one or more menu items for DOS (but Windows may not start), and one "good enough" (but no mouse and CD drivers) for Windows.
Reply 28 of 28, by carlostex
Suggestions:
- Your himem is taking more than 30Kb. Why? Keep DOS=HIGH,UMB remove AUTO
- Are you using a real hard drive or CF card? You don't need BUFFERS, set it to BUFFERS=1,0
- LASTDRIVE=Z do you need that many drive letters? Do LASTDRIVE=F
- Put I=B000-B7FF on your EMM386 line to use the monochrome memory area
- Stop using that VIDE CDD driver, use XDVD2 instead
- Why are you excluding CA00 up to DFFF?? Remove X=CA00-DFFF from the EMM386 line
