Ydee wrote on 2023-08-02, 09:22:
shevalier wrote on 2023-08-01, 13:01:
3. An ordinary office motherboard, if IT8282M did not burn out due to a poor-quality PSU, then it does not bring surprises.
Do you have any more detailed information on that? It is common issue? What are the symptoms?
https://dalincom.ru/datasheet/IT8282M.pdf
This is a controller for the sequence of power supply to various components of the motherboard, which, among other things, turns on / off the PSU.
It is powered by +5V standby voltage.
If the Power Supply goes crazy, then it usually greatly overvoltage the standby power to + 6 ... 10V.
From this IT8282 burns out. The motherboard usually does not turn on.
From personal statistics - 3 out of 3.
theiceman085 wrote on 2023-08-02, 09:37:
it is a necessity to learn basic soldering for maintaining the retro collection. In the long terms, I also want to learn it.
In order to learn how to solder correctly you need:
- remember that solder is a liquid;
- get a lens, soldering goggles, a microscope.
Before developing intuitive soldering skills, simply look at the behavior of the solder. It is immediately clear that the process is not going correctly.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
