Kitty Trouble wrote on 2023-08-06, 18:38:I think I found it.... […]
So I need a multimeter like this:
https://www.amazon.com/AstroAI-Digital-Multim … 1zcF9hdGY&psc=1
And USB like this?
https://www.amazon.com/%EF%BC%882-Pack-Comput … 1zcF9hdGY&psc=1
Will Windows 98's default driver handle this? I also don't know how to use a multimeter. Which I could try to find info on...but yeah
Those items should be all that is needed. The USB ports might be disabled by default in the CMOS settings, so be sure to verify that they are enabled. If you installed Win98 the preferred way (by copying the CAB files to the hard drive) then you won't even need to fish out your Win98 CD. If the ports are enabled in the CMOS settings, you ought to be able to have a look in Device Manager and see them now.
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
