Reply 20 of 21, by Sphere478
Zerthimon wrote on 2023-08-11, 21:20:
I have a motherboard with 3 VRMs with total of 20 nichicons 1500uF/6.3V, some of which are bulged. I would like to replace all of those nichicons with rubies 3300uF/6.3V (I ony got these in stock, currently). Will this work or is it a bad idea?
Different capacitors respond to different noise frequencies differently. You might actually end up, making it more noisy by increasing the capacitor size, also, as said above, power up inrush will be larger. Which may or may not be a problem.
Sphere's PCB projects.
Reply 21 of 21, by shevalier
CharlieFoxtrot wrote on 2023-08-13, 18:22:
Polymers of course change the look somewhat
https://upload.wikimedia.org/wikipedia/common … 56k_%281%29.jpg
Intel starting made motherboards with Sanyo Oscon capacitors during the Pentium Pro era.
What are they not like an ageless classic?
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
