Screamer 2
Reply 20 of 32, by Strauss
Nope, Screamer is the folder I set as my C drive. Setup installs the game in the folder name /S2.
Edit: I'm thinking, after about half a dozen reinstalls, that my CD might be damaged in some manner, so I'm downloading a new possible CD image for S2. Will see whether or not this is the case.
Reply 21 of 32, by Strauss
Nope, still didn't work. Can run through Install and Setup fine, but not the game.
Reply 22 of 32, by robertmo
you have to mount cd image with imgmount
Reply 23 of 32, by Strauss
Can't do that with the original CD. And there's no difference when I mount this new .img with Toast. What else could I try?
Reply 24 of 32, by wd
Rank DOSBox Author
DOSBox Author
Then use some cool OSX tool to create a cue/bin from that cd.
Reply 25 of 32, by Strauss
Not sure how that helps. Is running S2 with an image supposed to bypass the disc error?
Edit: Well, the new copy I've got here is an .img/.ccd/.cue/.sub. When I try mounting the .img file, the response is: Could not extract drive geometry from image. Use parameter -size bps,spc,hpc,cyl to specify the geometry.
Any one of those I should try?
Oh crap, I just realized that this was created with CloneCD. D:
Reply 26 of 32, by wd
Rank DOSBox Author
DOSBox Author
Depending on what cdrom interfacing can be used by sdl/dosbox to directly
access the cdrom on OSX the cue/bin should be superior. If it works then i don't know.
Reply 27 of 32, by Strauss
And apparently, I can't find a ccd-to-bin converter for OSX. >_>
Reply 28 of 32, by robertmo
There are bugs in dosbox imgmount messages (it displays wrong messages)
You can mount cue/img too.
You have to mount .cue file and at the end you need -t cdrom
Reply 29 of 32, by Strauss
robertmo wrote:
There is a bug in dosbox imgmount messages.
Give the man a damn prize. 😁
Works like a charm, game runs at full speed with no hiccups so far; thank you so much.
Reply 30 of 32, by wd
Rank DOSBox Author
DOSBox Author
Is that too unexplicit in the readme? And don't see any wrong message given
that imgmount's default (cdrom omitted) are harddrive images.
Reply 31 of 32, by robertmo
well.. we could remove all dosbox messages cause everything is in the readme 😉
Reply 32 of 32, by wd
Rank DOSBox Author
DOSBox Author
Why should the correct message be removed?
I said the *reason* for the given message is in the readme.
