Reply 20 of 21, by SDumas
SDumas
Offline
Quick update:
I managed to boot this motherboard with an 720K and 1.44M floppy drive.
1.44 MB floppy drive only boots with a 720K disk...
I'm doing some tests with the hard disk (Tandon TM262 - 20MBytes) and controller card (WD1002A-WX1) that came with this motherboard, but I'm not having any luck so far.
But here I don't know how to configure the hard disk, apparently it's through the WD1002A-WX1 in the jumper set S1.
I have been using the configuration that came on the controller board (WD1002A-WX1), but no luck...
This hard disk have a fresh install of DOS 6.22.
When I have availability, I will do more tests...
