ruthan wrote on 2024-12-03, 01:42:
>DDLink:
Please forgive the >old-style-quoting
I prepared this response offline.
>its using ownprotocol and for Dos to Dos
Well, I did kinda say this in my initial message where I advised of DDLINK and
that it might be applicable... (Perhaps you didn't feel like reading that part?)
>>It uses it's own protocol to transfer (basically the same messages over
>>network, serial or parallel) - this protocol is documented in detail within
>>the DDLINK documentation ...
>>Over a network the protocol is contained within "raw" packets, is not based
>>on IP or any other common network protocol. It therefore cannot be routed and
>>works on the local network only).
>>- A major plus is that it required no setup, address assignment etc.
>I need to access to Windows 10 share...
I've moved lot of stuff between DOS system and Win7/Win10 systems.
DDLINK itself is not Win32, but it does work very well under DosBox, which does
run on Win32 just fine.
I've recently updated my own DosBox distribution to improve it's SETUP program
which makes it quite a bit easier to configure it on a new system!
>(GUI itself seems good enough-2 panels-tab is working-
FWIW, It's not technically a GUI (Graphical User Interface). DDLINK uses text
screens presented through the text windowing library built into my compiler, no
graphics!
>only hotkeys seems a bit strange).
I'd appreciate any feedback on how exactly it's "strange". I *thought* I'd made
it fairly easy to figure out and use, but it's always hard to make such judgements
about your own work... (for some reason everything I design seems "obvious" to
me 😀
In this case, the two sides are presented as "directory lists", one on each side
of the screen... You can pick systems (sides) with right/left, and files with
up/down, PgUp/PgDn etc. The selected system/file is shown by the hilighted
directory entry.
The commands you can perform are shown along the bottom of the screen:
" A)ttr C)opy D)rive E)rase M)ult N)ew O)ption R)ename V)iew CR=Cd ESC=Quit"
I *thought* it was fairly obvious that:
- To change attributes (or timestamp) of a file, press 'A'
- To copy a file/directory (to the other side), press 'C'
- To switch to a different drive, press 'D'
- To erase a file or directory, press 'E'
- To perform operations on multiple files at once, press 'M'
- To create a new directory, press 'N'
- To change DDLINK options, press 'O'
- To rename a file or directory press 'R'
- To View a file (text or hex), press 'V'
- To switch to a new directory, press Carriage-Return
- To quit DDLINK, press ESC
I admit, wanting to take no more than one line from the screen, this command
"help" is not super-detailed. As there are confirmation prompts for dangerous
operations, a bit of experimentation should have provided a pretty good feel
for what these operations were going to do.
And... All functions are described in detail in the enclosed documentation file
DDLINK.TXT - but I do get that my choice to use such an obscure way to present
this information is difficult for many people to read (what the heck are .TXT
files? - what vendors "app" do I use to read it)
I originally designed DDLINK because it was something I needed and didn't have
plans to publish it - so it does "think a bit like me"....
I also wanted it to be simple and small, as I wanted one simple program I could
easily copy to/from a new system and not have to worry about installing or
configuring it... (I wrote the documents after I decided to make it available
to others - and kinda hoped that anyone interested in the program might read them)
So... I'm not keen on the idea of making it bigger, but I've made a trial
version with internal help screens... just press '?' in most places.
It relies on an accompanying DDLINK.HLP which it looks for in the same
directory from which DDLINK.COM was loaded!
The good news is that DDLINK.HLP isn't required! DDLINK will run just fine
without it - just the '?' help screens will not work!
I'm attaching DDLTST.ZIP to this message (it only has an updated DDLINK.COM and
DDLINK.HLP - use docs and other files from the original DDLINK distribution on
my site.
I can easily update the help text... any improvements or other revisions you'd
care to suggest are welcome!
Let me know if you find this to be a major enough improvement to make it usable,
and if so, I'll update the above mentioned original distribution.
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
- Dave ; https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChardware can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small FileTrans(w/o netSW)via Lan/Lpt/Serial
