Reply 20 of 32, by KainXVIII
- Oldbie
UCyborg wrote on 2025-05-16, 12:42:Wait, in which cases is this necessary? I don't have the problem with music playback with old DLL.
I guess this is useful if you don't wanna replace DLL files.
So crazyc meant to write "without", not "with". And if this is an error in Music.rrc, why is it suddenly the problem? Is MS fixing random bugs in old deprecated components? Assuming it was meant to error out in the first place in such case.
wrote:A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
UCyborg wrote on 2025-05-16, 13:01:So crazyc meant to write "without", not "with".
That's how i read it 😅
Yes, I meant without.
I suspect they fixed some other bug but forgot to check if the INFO chunk was empty. It then searches for the INAM chunk but ends up reading to the end of the file and then errors out.
If we're being pedantic, if I'm understating this right, we should be looking for the following sequences:
4C49535404000000494E464F
Breaking this down:
4C495354 - ASCII "LIST"
04000000 - length of the chunk - 4 bytes - 32-bit integer in little-endian
494E464F - ASCII "INFO" - start and at the same time end of 4 byte chunk
So, replace 4C49535404000000494E464F with eg. 4C49535404000000004E464F. I like zero terminating string at the start, turning it into empty string. This search pattern yields 168 results while search for INFOLIST yields 159. 🤔
Thoughts?
UCyborg wrote on 2025-05-20, 20:01:If we're being pedantic, if I'm understating this right, we should be looking for the following sequences: […]
Breaking this down:
494E464F - ASCII "INFO" - start and at the same time end of 4 byte chunkSo, replace 4C49535404000000494E464F with eg. 4C49535404000000004E464F. I like zero terminating string at the start, turning it into empty string. This search pattern yields 168 results while search for INFOLIST yields 159. 🤔
Thoughts?
Just since I had a case, have you checked the INFOLIST search from the top of the file, instead of stopping somewhere in the middle and searching the next instances?
The ones I've found problematic have LIST\x04\x00\x00\x00INFOLIST\x??\x??\x??\x??ins\x20insh where the "ins insh" LIST chunk has any size. The rest seem to be followed by a ptbl chunk, I don't know if those need to be fixed too.
BEEN_Nath_58 wrote on 2025-05-20, 20:11:Just since I had a case, have you checked the INFOLIST search from the top of the file, instead of stopping somewhere in the middle and searching the next instances?
That yields 159 results, like the pattern below, same count like I mentioned before. I always searched for all instances.
crazyc wrote on 2025-05-20, 20:32:The ones I've found problematic have LIST\x04\x00\x00\x00INFOLIST\x??\x??\x??\x??ins\x20insh where the "ins insh" LIST chunk has any size. The rest seem to be followed by a ptbl chunk, I don't know if those need to be fixed too.
Nice find either way, these chunks are still puzzling. I wonder if those chunks as they are have anything to do with occasional problem that music starts playing in fast or slow motion. So far, haven't encountered that with Win11's implementation, though perhaps I just haven't played enough yet. OK, it did happen eventually.
It does work for you then? No one has replied that it did work so if so it's good to know.
Yes, making a change using the pattern yielding 159 results seem sufficient.
Anybody has find a solution for local dmusic dll ?
crazyc wrote on 2025-05-16, 02:57:To make the music work with replacing dmusic.dll just open Music.rrc with a hex editor and replace all instances of INFOLIST with blehLIST (bleh can be anything that doesn't conflict with any other common RIFF chunk name). Dmusic checks for the INFO chunk in the DLS wavetable instrument description to have a valid INAM or ICOP chunk or it errors out. By removing the empty INFO it just skips it.
In fact, there is no need to replace dmusic.dll with this hex edit.
UCyborg wrote on 2025-05-12, 13:11:I didn't use anything from that ZIP specifically, I took DLL from my XP install, renamed original DLL in SysWOW64 and put the old one in its place. I like it manually so can't blame the script if something goes wrong. 😀
I just registered to this forum only to say that, holy sh*t, can't believe that worked. Thanks!
