Reply 20 of 24, by PC@LIVE
So if you rely on the automatic voltage recognition, it could be possible that it starts with a lower voltage, when with the P.MMX it starts at 125 MHz, this is normal, but if you switch to the jumpers manually, if you select for example 2.9V , you must have about 2.9V (+ or - 0.1V), does this tell you if it works or is there a problem?
Since the voltage becomes lower, according to what you have measured, if this is indeed the case, you could try the P.MMX at 200 MHz, and instead of 2.8V you can select 2.9V or even 3.2V, but I advise you to try the 2.9V, check the VCORE voltage, if it is low it should also be low at 3.2V, but pay attention to the temperatures, the ideal would be a k6 233, that has 3.2V from the factory, and can also work at 2.9V (perhaps not very stable).
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
AST Pentium Pro 200 MHz L2 256KB
Reply 21 of 24, by fsinan
PC@LIVE wrote on 2024-01-11, 20:20:
As I've written at the latest message. Manual setting gives 0.7V below what it should be.I've set 3.2V and it gives 2.6V and Pentium MMX works.
But When I set 2.9V for K6-2-333(it needs 2.2V), board gives 1.3V approx. And whatever voltage I set manually it gives 1.3.
System:1
Cyrix 5x86-120GP & X5-160ADZ
Lucky Star LS-486E
System:2
Intel DX4-WB & AMDDX4-120
PcChips M912 V1.7
System:3
AMD K6-2-475 & Cyrix 6x86MX PR-233
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 22 of 24, by PC@LIVE
fsinan wrote on 2024-01-14, 10:43:
Surely there is something wrong, in your last message the problem is clearer, but before putting your hands to the soldering iron and disconnecting something, there is one last test to do, if you go back to automatic recognition, enter the BIOS and check the VCORE, if it is for example 2.8V (in reality it would be less), can you try changing this value from BIOS?
It would be an attempt at a slight overvolt, if for example you put 3.2V check the real value (measured with the tester on VCC), then also check on the inductor next to it, they must be the same.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 23 of 24, by fsinan
At auto bios voltage setting can not be changed. Fixed at 2.8V but giving out 2.2V.
Changed all 4 capacitors around the cpu but it didnt change anything.
Flashed 2.0, 2.3 and 2.6 no change.
There is smething wrong but I can not find.
System:1
Lucky Star LS-486E
System:2
PcChips M912 V1.7
System:3
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 24 of 24, by PC@LIVE
fsinan wrote on 2024-01-27, 20:03:
At auto bios voltage setting can not be changed. Fixed at 2.8V but giving out 2.2V. […]
Well if changing the capacitors didn't change anything, the problem of low voltage still remains, I honestly don't know how that circuit is made, and even knowing it, I couldn't understand if it works normally, the ideal would be to have a similar motherboard for compare the voltages.
At this point what to do?
But one check I would do is measure the 3.3 5 and 12V lines, exactly how much do you measure?
If you find a big difference, it would explain why you measure low VCore voltages.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
