Socket 5 CPU limit?
Reply 20 of 23, by rmay635703
At this point some pentiums are expensive, if you luck out your p133 may have open multipliers and be overclockable.
That is what I would do in your case.
Reply 21 of 23, by dionb
Ribbicipp wrote on 2024-04-07, 16:37:
Thanks for the help. Glad i have some options with CPU upgrades on this board. I recently got myself a P1 133mhz (https://www.cp […]
I recently got myself a P1 133mhz (https://www.cpu-world.com/CPUs/Pentium/ ... -133).html) and im going to try and install it into my system. Gonna upgrade later on when i find myself a 166 or 200mhz P1 for sale at a reasonable price. Im thinking i'll stick with the pentium processors for my PC and not go crazy since I have no previous experience working on these older systems. I can build a new, modern system just fine, but there seem to be some key differences when working on new vs old systems.
As for installation of the 133mhz, how to i need to change the jumpers from how they are set as of now for my 100mhz?
Anything else i need to take into consideration or tweak before installing the 133 CPU?
Leave the 75/90/100 jumper where it is now (set to 100 = 66MHz FSB)
Leave BF1 as it is now.
Set BF0 to the opposite of what it is (can't make out if it's on 1-2 or 2-3 now, but whatever, you want the other option) for 2.0x multiplier.
That should give you 2.0x66=133MHz
Reply 22 of 23, by Schule04
Wouldn't adding a COASt module also increase performance?
Reply 23 of 23, by Ribbicipp
dionb wrote on 2024-04-07, 18:45:
Leave the 75/90/100 jumper where it is now (set to 100 = 66MHz FSB) Leave BF1 as it is now. Set BF0 to the opposite of what it i […]
Thanks, will try this out.
