Biostar MB-8433UUD-A
Reply 200 of 225, by CoffeeOne
Disruptor wrote on 2024-02-03, 20:23:
CoffeeOne wrote on 2024-02-03, 18:19:
Most likely you have got 20ns chips. 15ns chips usually can do 2-1-1-1 @40MHz
... when you drive 2 banks.
Yes, I agree. Double banked cache relaxes the timing.
I was able to get 512kB single bank cache stable at 40MHz on an Asus PVI-486SP3 with 15ns chips, but it was a really super hard to find 5 SRAM chips, that did it.
As a tag a Winbond chip with 10ns was used, but I am not sure if it was real 😁. But it worked in the end.
Reply 201 of 225, by jakethompson1
feipoa wrote on 2024-02-01, 12:54:
I may remember incorrectly, but I sorta recall motherboard versions which were sold with a UV EPROM chip contained a BIOS revision which did not try to update ESCD information. Did you see Updating ESCD... with your BIOS before you flashed it? Or did this only happen after you flashed it?
I'm pretty sure you need an EEPROM to update ESCD information. I don't think the UV EPROMs normally contain a EEPROM section to maintain ESCD.
For what it's worth, the original version of this board I used in the 90s had working Updating ESCD...Success only when a hardware change was made. As that was sold within an OEM system with a "Designed for Windows 95" sticker, I suspect the Windows Logo requirements might have included a working ESCD while those sold by the piece or to system builders may have used the cheaper part. The Updating ESCD also happened when encountering the "disappearing PS/2 mouse" problem mentioned in your manual, so the message was always bad news.
A few years back, I got one of these boards from eBay that came with a UV EPROM. It shipped with a BIOS named "UUD960326S." (notice the dot versus the normal version without). It printed "Updating ESCD..." at every boot but did not hang.
When I tried flashing a "modern" Flash chip (39SF010) it switched to hanging at Updating ESCD. I believe it has something to do with the original EEPROM being byte-programmable while the Flash chip is page oriented.
When I switched to a "period correct" EEPROM (29PHEE010) it went to "Updating ESCD...Success" only on hardware changes.
Later versions of Award BIOS, but not this old 4.50PG one, seem to have a list of allowed EEPROM/Flash IDs embedded in them, possibly to avoid the hang when it tries to program an incompatible chip.
Reply 202 of 225, by Disruptor
2-1-1-1 @ 40 MHz single banked in an ASUS PVI-486SP3
CoffeeOne wrote on 2024-02-03, 22:55:
Congratulations!
Do you still have that board?
And may you post a photograph of that SRAMs? 😀
Do you use an Am5x86 @ 160 or Cx5x86 @ 120?
Reply 203 of 225, by CoffeeOne
Disruptor wrote on 2024-02-07, 13:24:
Congratulations! Do you still have that board? And may you post a photograph of that SRAMs? :) Do you use an Am5x86 @ 160 or Cx5 […]
Congratulations!
Re: 3 (+3 more) retro battle stations
No, I don't have it anymore.
I used it with a Am5x86 @ 160.
Reply 204 of 225, by Yoghoo
Yes, I agree. Double banked cache relaxes the timing. I was able to get 512kB single bank cache stable at 40MHz on an Asus PVI-4 […]
Put back the original 15ns cache chips and it it's stable now at 40Mhz. Single banked cache btw.
Also played around with a Promise FastTrak TX2000 Ultra ATA/133 RAID card. I don't think it was mentioned here or in the unofficial guide yet but it works great. Only problem is that during a soft or hard reset it doesn't recognize my CF card. A cold boot works around that problem. Seems like a similar problem some people already mentioned with other Promise cards.
Reply 205 of 225, by supercordo
Just got this off ebay for i think a good price. Cant wait till it gets here.
Reply 206 of 225, by jakethompson1
supercordo wrote on 2024-06-13, 21:44:
Nice! I was watching that, since the seller did it as an auction and at a low starting price, letting people figure out what it's worth.
The ADZ CPU is nice because it doesn't need a heatsink.
The only issue is a v2 has the real time clock chip soldered in, so you've got a desoldering project to do (Award BIOS resets the settings on each boot if the battery is dead, so you can't really use DOS without a fresh battery).
Reply 207 of 225, by supercordo
jakethompson1 wrote on 2024-06-13, 22:11:
Nice! I was watching that, since the seller did it as an auction and at a low starting price, letting people figure out what it' […]
Yeah, i plan on adding a socket for the RTC.
It seems finding a Cyrix 120 is impossible. Anyone know if the IBM 5x86c 100GF will overclock?
Reply 208 of 225, by appiah4
supercordo wrote on 2024-06-13, 22:27:
Every IBM 5x86-100 I have, well, both IBM 5x86-100s I have, overclock to 3x40MHz fine.
Reply 209 of 225, by feipoa
Which listing? When I check completed listings, they all have sold for "best offer" value, thus I'm not sure what their current market value is, but it certianly has fallen. I suspect they are going for about $99 right now.
How fast can the ADZ be clocked at without needing a heatink? I thought they all have "heatsink/fan required" written on the ceramic surface?
Reply 210 of 225, by majestyk
feipoa wrote on 2024-06-15, 07:26:
Not all of them have this writing.
I have several ADZs and they usually run stable at 133MHz without heatsink/fan. When I overclock them I always mount a (passive) cooler first.
Reply 211 of 225, by feipoa
What’s the CPU’s surface temperature after 20 minutes of 100% cpu utilisation?
Reply 212 of 225, by jakethompson1
It was US $137.50 plus shipping: https://www.ebay.com/itm/196430572860
So $99 plus whatever those goodies are worth (CPU and RAM).
Reply 213 of 225, by supercordo
Unfortunately the board doesn't have any L2 cache. I have some W24257AK-10 on the way as well.
I haven't decided what video card i'm going to use with it yet but i have an ATI rage 128 pci ill use for now.
Reply 214 of 225, by jakethompson1
supercordo wrote on 2024-06-16, 23:28:
Nice.
I used a Sams Club special system that came with this board, and they put a Cirrus Logic 5446 in it.
Reply 215 of 225, by supercordo
Any one try an Nvidia Vanta in their build?
Reply 216 of 225, by appiah4
supercordo wrote on 2024-06-19, 22:14:
I have a Riva128 in mine and it works wonderfully.
Reply 217 of 225, by supercordo
The Vanta is from the NV5 TNT2 family.
Reply 218 of 225, by Yoghoo
Did anybody did a recap of a Biostar MB-8433UUD-A motherboard before? Thinking of recapping my board as I have sometimes PS/2 mouse detection problems (not the known issue btw) and going to replace the PS/2 port and can do it in one go if needed.
Question is more if it was needed for anybody. Caps look good but are getting old of course. If somebody did it do you have by change a cap value list?
Reply 219 of 225, by feipoa
I remember recapping this board in 2012 with aluminium polymer caps. I don't know if this type of capacitor is ideal for this motherboard, but the operational outcome was the same as the original caps. I'm pretty sure this board is in my IBM 5x86-133/2x QFP based system.
