Reply 200 of 216, by Benedikt
root42 wrote on 2020-08-30, 22:23:
You can use some software to re-encode your capture as 4k and upload that to YT. It will force YT to use higher bitrates and resolution, leading to better visual quality. Even if your original material wasn't 4k to begin with.
I can't get over the wastefulness that video platforms provoke with their lack of configuration options.
Anyway, has anyone given pixel shaders a thought? While I have no experience writing pixel shaders, they could potentially make the filtering process lightning fast even on slightly older systems.
Reply 201 of 216, by root42
Yeah, color conversion possibly could be done in a pixel shader... we could even support RGBrgb that way.
By the way, my OSSC also has significant jitter on my Tseng VGA when running in 800x600 and a little bit when running in 640x480. I think the digital sampling really shows the imperfections of the old video cards. A CRT probably smoothes this out with its sync circuits.
YouTube and Bonus
Reply 202 of 216, by Benedikt
I think that it's mostly due to a lack of synchronization, i.e. due to sampling "between pixels", but there could be imperfections in the signal itself, too.
Reply 204 of 216, by imi
just the right amount of messy ^^
Reply 206 of 216, by Pierre32
Predator99 wrote on 2020-09-05, 20:35:
SIGROK2EGA at its best...now I am happy with the Youtube-Quality...select 1080p HD ;-) https://youtu.be/FvCjBuS9NBc Sound is fro […]
SIGROK2EGA at its best...now I am happy with the Youtube-Quality...select 1080p HD 😉
Sound is from a Crystal/Dream Wavetable card I am currently testing, also sounds amazing.
SC8500 sound card - what does it do?
Looks spectacular! Amazing progress.
Reply 208 of 216, by kdr
I've recently ordered a couple of cheap Cypress FX2LP eval boards from China (so they'll take ages to arrive) because I need a 16ch logic analyzer to debug an old Turbo XT motherboard with glitchy DMA. I'm also hoping to be able to play with Predator99's awesome video capture code!
In preparation I have been digesting the FX2LP datasheet and reference manual. Gosh it's a complicated device! But it's given me some thoughts on how to improve the video capture, provided you have access to some of the extra pins on the FX2LP chip (RDY0/1). Basically the idea is to route HSYNC to one of the RDYx inputs and use this as a hardware trigger to begin/end the capture of a single scanline. During one scanline you are still reliant on the internal 30/48Mhz clock to capture the pixels [so there will be some drift] but the hardware can automatically resync at the start of each new line, so the drift would be roughly identical for all lines.
As a bonus, there would be no need to transmit any data during horizontal blanking, reducing USB bandwidth requirements and letting the capture speed get cranked up...
Reply 209 of 216, by root42
That would be excellent news, if possible. Could become a very nice capture device with little visible jitter.
YouTube and Bonus
Reply 210 of 216, by Predator99
Would also be happy to see that! However, with hardware modification this wouldnt be "Plug&Play" anymore.
Reply 211 of 216, by Benedikt
kdr wrote on 2020-10-15, 01:44:
In that case, it's probably time for custom boards.
A small PCB with an edge-mounted DE9 connector on one end and micro USB on the other would fit nicely in a shielded standard enclosure for D-Sub adapters.
Reply 212 of 216, by matze79
Any Progress on this ?
Reply 214 of 216, by root42
charlysan wrote on 2024-06-24, 21:44:
Great project! I've done some experiments (before discovering this project) using a Hercules Graphics Card. The project wiki can be found here:
https://github.com/charlysan/x86_stuff/wiki/C … -logic-analyzer
https://github.com/charlysan/x86_stuff/tree/main/lavct
Very good writeup, thanks! I think the issue right now is that things like the RGB2HDMI are readily available as a "plug and play" solution with HDMI support. The sigrok solutions are definitely very impressive and very, very cheap. But I think it's more for tinkerers who don't need HDMI support. but want to record raw footage. Probably not that huge a market.
But your analysis would be useful for other TTL video signal formats, like CGA and EGA, too.
YouTube and Bonus
Reply 215 of 216, by Predator99
With your knowledge you are welcome to improve sigrok2ega 😉
However, in the mean time there is another project called retoscreen:
https://github.com/COMBudda/RetroScreen
Picture quality is not perfect and sigrok2ega looks better. But it has direct Hardware access without using sigrok. Its much faster and better for everyday usage.
Reply 216 of 216, by charlysan
Predator99 wrote on 2024-06-25, 20:44:
With your knowledge you are welcome to improve sigrok2ega ;-) […]
Thanks for sharing that. I'd be glad to contribute to sigrok2ega project.
