Reply 200 of 380, by Oetker
- Oldbie
Is there a reason NOT to enable the sb mixer mode? And is there a command-line parameter to pass to cmmix to auto-enable it? I couldn't find any documentation on the parameters it generates in autoexec.bat.
I've only tried Doom 1/2, Duke Nukem 2 and 3D (2 to confirm missing adpcm) and Lemmings. Only issue thusfar is that, as mentioned in the ctrl-alt-rees video, FM audio volume is a bit low. But I'm very happy that I can play Duke3D with 16-bit mixing and bug-free midi. And sure these games generally have low-quality sound effects, but they still sound a lot better than on my old Aztech card.
I also have to add that the Windows drivers are good, it's a bit strange that you have to pick between the SB16 and WSS audio devices (though it makes sense), but on other cards I've had issues like DOS/Windows breaking each other, nothing like that here.
