Reply 200 of 475, by lausvi
FreddyV wrote on 2024-08-17, 20:58:Yes, this is it, it is on purpose. The uSD and USB connectors are too close from the PCB. These kind of connectors did not exist […]
lausvi wrote on 2024-08-16, 14:36:I meant the red line in the attached pictures: the board is not parallel to the bracket: […]
This is how I plan to install the audio output jack:
These kind of connectors did not exist at the ISA time
Ah, now I see, the problem is the metal between slots on the PC cover that blocks the SD-slot (as it sits so close to the PCB). Sorry I didn't understand the issue at first 😊
This seems to vary between cases. I 3D-printed my own bracket with the PCB straight, and tested on my Pentium I case; the SD-slot just clears the case so it might work, depending of the case's tolerances. I'll need to test on another case to see if this was just lucky exception.
I now have another question! I have a Commodore PC-I (https://www.zimmers.net/cbmpics/cpci.html), which I think would really benefit having a PicoMEM: it only has one ISA-slot (and only by using an external adapter: https://autumnhippo.com/products/pc1-xt) and it's very low-end XT clone. Having a hard disk, AdLib and networking on it would be a really neat treat (also no need for the bracket, hah).
I installed the PicoMEM on my PC-I and it does work (hard disk, AdLib and networking tested so far) BUT there is a somewhat random issue where sometimes (most of the time actually) the machine freezes at "PicoMEM Boot: Press A to boot from floppy , B for BASIC/ROM 1". The count-down at the end of the line stops at 1 or 2. At this point the internal floppy-drives's light is on, and when the boot halts, the light stays on (when it boots succesfully, the floppy drive light goes off after the hard disk boot has started). If I keep resetting the computer, I eventually get it to boot succesfully either by just not touching the keyboard at all, or bashing keys on the prompt and it just proceeds normally. I had no issues with the PicoMEM itself as I tested it on a loose 386 motherboard.
I noted some mentions of a timing issue with Commodore PC-10, could this be something similar (what was the issue on that machine?). Or as mentioned in a recent issue on the GitHub (https://github.com/FreddyVRetro/ISA-PicoMEM/issues/41) perhaps a power issue? Are there any easily reachable spots on the PicoMEM PCB to add additional capacitor for testing?
I did see couple of times an error about config not being saved/SD card not accessible, could this be a power issue as well? (The SD card is new and freshly formatted, although a cheap 4GB one).
