Reply 2000 of 2282, by djvj
Hi,
First, thanks so much for this great front end to dosbox you have made. Have been using it for a long time.
I've recently updated to the latest D-Fend Reloaded 1.4.1rc1 and dosbox svn r3869. I've always launched dfend via CLI like this: dfend.exe "game name"
I noticed that in the dosbox console window, it's always loading the dosbox.conf file from my temp folder, and no matter what I have tried, it won't read it from anywhere else.
DOSBox version SVN Copyright 2002-2013 DOSBox Team, published under GNU GPL. --- CONFIG:Loading primary settings from config fil […]
DOSBox version SVN
CONFIG:Loading primary settings from config file C:\Users\djvj\AppData\Local\Temp\DOSBOX.CONF
In dfend's program options, it is sending the additional CLI as -conf "D:\Emulators\DOSBox\D-FendReloadedPortable\App\D-Fend Reloaded\Confs"
dfend deletes a dosbox.conf if I play one there. I also tried changing that folder to something else that did not help either. Dosbox recreates that dosbox.conf folder on each launch, so editing that file doesn't help as it gets restored again on each launch.
What am I missing here so I can have a launch through dfend cli load the correct conf file?
