Reply 2000 of 2325, by Falcosoft
- l33t
Spesek wrote on 2024-09-28, 19:12:Hi, Thanks for your response, Zoltan. […]
Hi,
Thanks for your response, Zoltan.1. Yeah, I agree. And some files don't mark, well, anything at all. I have to manually set up 0x21 messages for it to work properly which can be a pain.. Fortunately MIDI 2.0 solves this issue, except it's almost non-existent right now and useless for retro tracks... MIDI 1.0 should've just used a separate byte for status and a second one for the channel IMO, it would've made things a lot simpler.
2. I see... May I ask for some sort of pseudo-code on the logic FSMP6 uses for determining these? I'd like to implement this functionality into my synth if you don't mind...
1. AFAIK only the Midi 2.0 protocol is ready but currently there is no Midi 2.0 equivalent of SMF files. Or have I missed some new developments on this area?
2. OK, maybe later. I have to find the relevant parts. Most likely I will give you native Pascal code 😀
