DOSBox Game Launcher (DOSBox Frontend)
Reply 2180 of 2214, by Neville
I just build a portable DBGL with some games and DOSBox Staging in order to demonstrate the new Sound Canvas emulation to some friends. However, I noticed I still had to add the "soundcanvas" switch to the "mididevice_staging0810" section in the Dynamic Options. I'm using latest beta, dbgl0100beta17. I'm a bit confused, because right now I can't remember if any stable version of DOSBox Staging has already included the Sound Canvas emulation. Anyway, maybe it's time to start including the option.
The Sound Canvas section on the dosbox-staging.conf file also has a few options, but I don't know if they deserve its own section on the profile editor. Here they are:
[soundcanvas] # soundcanvas_model: The Roland Sound Canvas model to use. # One or more CLAP audio plugins t […]
[soundcanvas]
# One or more CLAP audio plugins that implement the supported Sound Canvas
# models must be present in the 'plugins' directory in your DOSBox installation
# or configuration directory. DOSBox searches for the requested model by
# inspecting the plugin descriptions. The lookup for the best model is
# performed in order as listed.
# auto: Pick the best available model (default).
# sc55: Pick the best available original SC-55 model.
# sc55mk2: Pick the best available SC-55mk2 model.
# <version>: Use the exact specified model version (e.g., 'sc55_121').
# Possible values: auto, sc55, sc55_121, sc55_120, sc55_110, sc55_100, sc55_200, sc55mk2, sc55mk2_100, sc55mk2_101.
# soundcanvas_filter: Filter for the Roland Sound Canvas audio output:
# on: Filter the output (default).
# off: Don't filter the output.
# <custom>: Custom filter definition; see 'sb_filter' for details.
soundcanvas_model = auto
soundcanvas_filter = on
Oh, and 've been thinking about those PC-98 self-booting HD images I talked about earlier. Made me realise there's not an option in DBGL to boot PC harddrive images either. I can see why not, because it's not something one would usually need. Anyway, if there's room in the Mounting tab and the feature is added to any of those systems (PC or PC-98), why not both?
And well, if adding this feature is out of the question, I can always write a BAT file to launch these rare games that need booting from an HD image. There aren't that many .
Reply 2182 of 2214, by rcblanke
kolderman wrote on 2025-10-03, 20:53:
I get an error:
i get an error minimum windows build version 14393 but currrent is 7601
Maybe there are some left-over temporary SWT files from the 'new' jar. Please try removing (or renaming) the .swt folder in your home directory.
Reply 2183 of 2214, by rcblanke
willow wrote on 2025-11-03, 20:44:
Good morning
Do you plan to support DOSBox Pure Unleashed, new version standalone of dosbox pure https://github.com/schellingb/dosbox-pure-unleashed ?
Hi willow; that is quite unlikely, as this particular DOSBox fork seems mostly intended to be used stand-alone, using it's own gui etc. Unless there actually IS a compelling reason to use it with DBGL?
Reply 2184 of 2214, by rcblanke
Neville wrote on 2025-10-11, 20:15:
..Oh, and 've been thinking about those PC-98 self-booting HD images I talked about earlier...
For the moment, I'm working on implementing .HDI browsing. More work is underway, but as usual, the last months of the year are the busiest for me - so it might take some time.
Reply 2185 of 2214, by Neville
Sure, take all the time you need. I also imagine it's not a very urgent or popular feature.
Reply 2186 of 2214, by willow
rcblanke wrote on 2025-11-25, 19:08:
Good morning
Thanks.
Reply 2187 of 2214, by wesbat
Greetings! I've been using DOSBox Game Launcher for a while now, I am an ex-DFend user and found this to be an excellent replacement. Thank you for making this possible!
I am setting up a laptop for a family member, and would like to export some of my games for them. When I try use the export function (Game data + captures) I reach step 2 but can't get past this page, the app reports that "the game directory XYZ is invalid, it must be relative to the dosroot"
I am unsure what this error is saying. The directory does exist. I have tried changing the directory to various other locations to test what works, but not having any luck. What exactly does dosroot refer to? Is that the path that is mounted as the C drive?
Each game has its own directory mounted as C drive, attached are snaps of the mount configuration.
Any advice will be appreciated 😀
$ java -version
openjdk version "21.0.9" 2025-10-21
OpenJDK Runtime Environment (build 21.0.9+10-Debian-1deb13u1)
OpenJDK 64-Bit Server VM (build 21.0.9+10-Debian-1deb13u1, mixed mode, sharing)
Running DBGL 0.99
Reply 2188 of 2214, by wesbat
Apologies, I solved it.
I used the find command to discover the dosroot location at ~/.local/share/dbgl/dosroot, pointing to that path allows the next export step.
Thanks! 😀
Reply 2189 of 2214, by wesbat
Oh, okay so the exported archive does not contain the game files at all, it contains whatever is in the dosroot directory (which is empty on my setup).
So I guess the export feature won't work for games that mount their drives from paths outside of dosroot?
Reply 2190 of 2214, by rcblanke
That is correct wesbat. DBGL will use relative paths only if the target file or directory is located underneath a certain location (in most circumstances, DOSROOT). Locations outside are considered absolute. The reason for this is that by using this logic, one can safely move the DBGL directory to another location without breaking any file or directory locations.
Reply 2191 of 2214, by red_avatar
Just a small "bug" I found: if you try to mount an ISO or CUE file stored on a network drive, you get "null" instead of the actual link. I have to mount the folder to a drive letter before DBGL will correctly link to it. Oddly enough it doesn't do this with other folders or files?
Also: if you boot DBGL off the drive via the drive letter (for example N:\DBGL) it will see the folder as \\NASDRIVE\MYDRIVE\DOSGAMES\DBGL - this too used to be different. I mean, it's more correct and not dependant on the mount letter to remain the same but it seems to have some issues working with network links.
Retro game fanatic.
IBM PS1 386SX25 - 4MB
IBM Aptiva 486SX33 - 8MB - 2GB CF - SB16
IBM PC350 P233MMX - 64MB - 32GB SSD - AWE64 - Voodoo2
PIII600 - 320MB - 480GB SSD - SB Live! - GF4 Ti 4200
i5-2500k - 3GB - SB Audigy 2 - HD 4870
Reply 2192 of 2214, by remax
Hello,
a small bug report :
I have a Database query "update profile" failed! error when grabbing info from Mobygames and the resulting infos leads to a too long line in one of the box
Exemple Doom, Publisher -> "id Software, Inc., Atari Corporation, SoftKey Multimedia Inc., Micro Star Software, SEGA of America, Inc., SEGA Enterprises Ltd., Tec Toy Indústria de Brinquedos S.A., Imagineer Co., Ltd., Art Data Interactive, Inc., Williams Entertainment, Inc., Ocean Software Ltd., Basho House, Activision Publishing, Inc., Simon & Schuster Interactive" is apparently too long for DBGL and you must shorten it to be able to save your profile.
Reply 2193 of 2214, by Neville
DOSBox-X v2026.01.02 is out, but I don't see any new features that might affect / break what's already implemented in DBGL.
If that, this one:
Update BOOT command to support multiple disk images with swapping (maron2000).
You can read the complete changelog here.
Reply 2194 of 2214, by Monotremata
Neville wrote on 2026-01-03, 17:02:
DOSBox-X v2026.01.02 is out, but I don't see any new features that might affect / break what's already implemented in DBGL. […]
If that, this one:
I'm on a Mac here. The December release has some issues, so I'm still using the October one. For whatever reason it completely ignores my display settings and seems to keep the resolution at DOS's actual settings. I now have to 'Force' the scalers to make my window resize properly. Even dragging the corner of the window to resize, will resize the window, but keeps my DOS screen at 320x200 or whatever in the middle of the window. Even trying to change settings using the menu bar, does nothing, changing settings inside DOSBox-X's config GUI does nothing. It's completely ignoring some of my config file and when I change settings live in the app itself.
The January one just keeps crashing on me. I got it to start opening once, asked me to set my new working directory and then disappeared. Now when I open it, it just immediately crashes heh.
EDIT: Looks like someone already reported it crashing on macOS Tahoe in the Bug Tracker a couple hours ago haha. Thank god it's not just me. After the weird scaler stuff with the December release, I started digging through the system to wipe everything and start over thinking something got corrupted..
Reply 2195 of 2214, by Deffnator
For some reason, DBGL is freezing up with the latest staging nightly builds.
EDIT: nvm it was 099 not working with it, the beta release is fine
Edit2: well a interesting development
For some reason TFX doesn't want to work on DBGL, without it it works fine under the latest nightly build of Staging, with one caveat, which i'll report for them later, which is the game having problems with SB16 but working fine as Soundblaster.
Reply 2196 of 2214, by AlfreX
Hello! First of all, I want to thank you for all your work and this fantastic front end.
I would like to make a small request. Would it be possible to add the option to display screenshots of each game in the right-hand column, above the description?
I think this would make the collection more attractive and practical, as having a column at the bottom, in my humble opinion, takes up a lot of visual space.
Thank you very much in advance, and I look forward to the new version.
Reply 2197 of 2214, by Gryzor79
Hi everyone, first post here 😀
I might have stumbled upon a peculiar bug in the latest 0.99 release.
You know there is the feature to juggle between dosbox versions for a given game profile. In the menu "Dosbox" menu where you can do that, you can either "set", "switch" or "set to default" when you point the profile to a new Dosbox.
Also, as pretty much everything with DBGL, you can do so in bulk, which is extremely useful when willing to migrate every single profile in your collection when you're certain the newer Dosbox install works everywhere.
But, and I have noted this only a few days ago, and maybe this is only my case or a corrupt install, I noticed some dysfunction :
Whenever I try to switch a given configuration to, say , the latest Dosbox 0.83 dev build from the 0.82 release, it works, and I get then launch DBGL with it. But, whenever I want to then return and click again on the "Dosbox" section to check or modify again => DBGL just hangs and has to be forceclosed.
Any idea why would that happen ?
Just in case I attached the section and buttons I was refering to.
Thanks for your help.
Reply 2198 of 2214, by Neville
The latest official build of DOSBox-X is here. DOSBox-X v2026.03.29 has just been released, and you can consult the changes here.
A few of the new features imply new options being added to the dosbox.conf file, but we're talking about really minor stuff, such as:
Add dosbox.conf option to control the duration of the beep when DOS CON and INT 10h are given the BEL character. (joncampbell123 […]
DOS CON and INT 10h are given the BEL character. (joncampbell123).
Add dosbox.conf option to control whether VBE emulation provides the
protected mode interface or not (joncampbell123).
So I don't think DBGL needs to bother about them.
Reply 2199 of 2214, by Monotremata
Go figure I just built it myself last night and now they release it the next morning hah.
