Reply 220 of 224, by Calolo
I checked the CPUid and the C3 Nehemiah 1200 only support SSE.
Because this CPU was released after DX7 maybe it is not detecting/using SSE?
DOS/98SE : PIII-S 1400/C3 1200, GA-6BXC 2.0, 256MB PC133 C2, GeForce 2 Ultra, Voodoo2 12MB, Audigy1 Platinum Ex, ESS1688, SSD 128GB
XP/7 : i5 3750k, 8GB DDR3 1600, GTX 280 1GB, Radeon X1950 XTX, SSD 512GB
Reply 221 of 224, by B24Fox
@bloodem
In a benchmark video you posted a few years back, titled "Asus P5A & AMD K6-3+ 570 OC @ 633 MHz Benchmark (with GeForce2 MX400)" https://youtu.be/w5x79oP_vks?si=1IZhR-EJ5QwYAwo7&t=750, you got Expendable to show the "Optimized For AMD 3DNow!" logo, when starting the game.
How did you do that???
I got the same CPU and GPU, and it doesn't show it (leading me to think that the game is not enabling 3DNow! for me)
I'm using Win98SE, and nVidia drivers v8.05, on a VIA MVP3 chipset mobo... in case that matters.
<<The UNIFIED Passive-Adapters Thread for Mice, Keyboards, Joysticks & more>>
Reply 222 of 224, by bloodem
B24Fox wrote on 2026-01-28, 01:28:
@bloodem […]
@bloodem
Expendable always displays that logo when running on a CPU that supports 3DNow! instructions, however it only displays it at 640 x 480, IIRC.
So, if you're running your benchmarks at higher resolutions it will show a black screen instead.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 223 of 224, by B24Fox
bloodem wrote on 2026-01-28, 08:32:
@bloodem […]
@bloodem
God bless you! You just saved me a windows reinstall!
Indeed, for some reason, only 16bpp resolutions display that logo (which I usually always avoid)
Thank you!
Reply 224 of 224, by bloodem
B24Fox wrote on 2026-01-30, 03:47:
Thank you!
Glad it helped. 😀
