Reply 2280 of 2663, by Falcosoft
- l33t
Roland User wrote on 2025-08-10, 22:50:Hi Zoltan )
I have question but this will full offtop in this theme ) your player work very good , but I use WMP and as known in 2038 this player will stop work , I wanth use single player for Tracker and MIDI files , I was select XMPlay , but I have problem and this problem https://www.un4seen.com/forum/?topic=20713.0 , maybe you can write plugin for read and MIDI / XMI /RMI and simlar formats for XMplay with output to selected MIDI device , but not soundfont ? Approximately as work your WinMM MultiPort VSTi only for XMPlay ?
Hi,
I have never written an XMPlay plugin so I do not think that I'm the right person for this task.
Let's talk about this problem again in 2037 😀
