Reply 22840 of 58946, by Ozzuneoj
- l33t
wrote:The industrial computer I posted a pic of a while ago showed up today. It is a super custom jobbie made specifically for the mot […]
The industrial computer I posted a pic of a while ago showed up today. It is a super custom jobbie made specifically for the motherboard in it.. an ASUS P2B-LS.
Video card is a Diamond branded Riva 128. Also has a 3Com network card and a couple other cards. Kinda looks like it was used for some sort of video capture or processing of some sort. The one PCI slot looks like something was removed from the system at some point.
CPU in it is a PII-450 and a single 128MB stick of RAM. The SCSI HDD is ~4.5GB.
The power supply is custom made and nowhere near a standard size.
I did not take another pic of the front of it since the one I posted a while ago from the seller shows it just fine.. basically just power, leds, 3.5" floppy and a SCSI port. I might be modding the case so I can use an optical and 3.5" drive. Not really any room for anything else.I'll probably just use this as a dedicated PII or PIII Slot-1 system with the motherboard that came with it. The motherboard has a PC/PCI header so that is another plus.
Wow, that thing looks like a crazy hybrid IBM 5150 ATX SFF system...
