Reply 23740 of 31271, by Shponglefan
- l33t
ChrisK wrote on 2023-02-13, 16:55:I'd suggest reflashing the BIOS. Wouldn't be the first board appearing dead but a simple reflash could bring back to life. I had […]
Shponglefan wrote on 2023-02-12, 00:21:Replaced some capacitors on this SOYO SY-5EMA+ V1.0 motherboard. […]
In initial testing I couldn't get it to POST. One of the 1000 uF caps was budging so decided to de-solder and replace all the 1000uF caps.
After testing them it turns out only the one cap was bad. Oh well, no harm in replacing all them I suppose. At least they now match the other caps on the board. 😁
Not sure if this fixed the issue, but we'll see once I get around to testing the board again.
edited to add:
Didn't fix the problem. Still won't POST. It's getting power, fans spin and various components (including the CPU) get warm. But no POST, no beeps.
Back to the drawing board.
I had several socket 7 boards with no signs of damage but not POSTing. A reflash with the correct BIOS brang them back to life.
Another slot A even POSTed with beep codes indicating bad memory or graphics card. None of that was the case, after reflashing the BIOS it worked like a charm.
That's good advice.
I do need to test the BIOS chip to make sure it's working and I suppose reflashing it couldn't hurt.
