Reply 240 of 240, by Kamerat
- Oldbie
mwdmeyer wrote on Today, 09:52:... 0.35 is out https://github.com/michaeldale/velocity9x/rel … ses/tag/v0.35.0 […]
0.35 is out https://github.com/michaeldale/velocity9x/rel … ses/tag/v0.35.0AMD Radeon HD 7660D + NVIDIA RIVA 128ZX (not finished) + Intel GMA
Thanks, nice to see support for a TeraScale 3 GPU/APU!
Duffman wrote on Today, 13:05:It's definitely something windows related as DOS is fine.
I started going through every device in device manager and I did find the culprit, but it's bad news for debugging/testing though.
It's the 3Com NIC built in to the laptop, disabling the NIC in device manager stops the freezing, but that also means that we won't be able to run debugging on it with it disabled.
I suspect that the 3Com NIC share some resources with other devices that might cause a problem. Open "Device Manager", select "Computer" and click on "Properties" and have a look at the resources, especially the IRQs.
