The Soundblaster DSP project
Reply 240 of 1148, by Maelgrum
S95Sedan wrote on 2023-09-30, 18:47:
CT1730, v404 CT2750 v411 CT3900 v413 (All original roms) […]
CT1730, v404
CT2750 v411
CT3900 v413
(All original roms)
Thanks, S95Sedan !
Looks like i coded all basic stuff good.
Next steps require a external midi loopback (MIDI OUT to MIDI IN).
Just bought D-SUB connector for gameport on SB, will solder 2 wires to do loopback. (MIDI cable from OUT to IN also can be used).
Reply 241 of 1148, by georgel
Maelgrum wrote on 2023-09-30, 18:53:
maxtherabbit wrote on 2023-09-30, 18:44:
Here's the output from one of my CT2230s running 4.13 patch3
RAM dump looks good, thank you maxtherabbit !
The method to change SP won't work on 8052 because SP is mapped at RAM address 182h while the SB function FA (and F9 for reading) accepts only byte as an address value and therefore is unable to access SFRs on 8052. I haven't looked at your SBDUMP but I guess it is reading only the first 256 bytes of RAM while SP lays beyond that address space.
Reply 242 of 1148, by Maelgrum
Gmlb256 wrote on 2023-09-30, 19:01:
Here is a dump from the AWE64 CT4520, DSP v4.16.
Edit: Added LOG.TXT.
Thank you for testing, Gmlb256 !
Reply 243 of 1148, by Maelgrum
[/quote]
[/quote]
You are right, but attack via MIDI OUT to IN is possible.
R1 is accessible in RAM.
Reply 244 of 1148, by mattw
Maelgrum wrote on 2023-09-30, 19:02:
I am not sure about what is your idea, but do you know "awe_dump" and I don't mean the tool you made, but the almost 30 years old tool that makes dump of EMU8000 ROM - I am attaching it - it's written in Pascal thus the source code is a little hard for me to read. So, maybe if the DSP includes some EMU8000 commands or communication, you can use EMU8000 as entry point to execute code inside the DSP - maybe I am talking nonsense I don't know, but in any way, maybe in final version of your Dumper nice addition (for completeness of features) will be to include EMU8000 ROM dump as well, even if it's not usable for DSP attack.
Reply 245 of 1148, by georgel
Maelgrum wrote on 2023-09-30, 19:06:
[/quote]
[/quote]
Yes, R1 is accessible but since it is initialized upon entry to UART mode with SB function 34h and UART mode is terminated only via 8052 reset there is no use of R1?
Reply 246 of 1148, by Maelgrum
georgel wrote on 2023-09-30, 19:11:
[/quote]
[/quote]
It must be initialized also by MPU init. A then we can modify it.
Reply 247 of 1148, by S95Sedan
Thanks, S95Sedan ! Looks like i coded all basic stuff good. Next steps require a external midi loopback (MIDI OUT to MIDI IN). J […]
Thanks, S95Sedan !
Pin 15 <> Pin 12 i assume?
Reply 248 of 1148, by Maelgrum
Here, i do initialization of MPU, and then read memory dump.
In second byte of dump, we must see 0x40
Reply 249 of 1148, by maxtherabbit
Maelgrum wrote on 2023-09-30, 19:19:
this one is meant to be used with MIDI loopback?
Reply 250 of 1148, by georgel
Maelgrum wrote on 2023-09-30, 19:14:
And then one must activate UART mode with SB command 34h which in turn will reinitialize R1 value.
Reply 251 of 1148, by Maelgrum
S95Sedan wrote on 2023-09-30, 19:17:
Thanks, S95Sedan !
15 <-> 12, and 4 <-> 5 (this may be unnessesary)
Reply 253 of 1148, by Maelgrum
maxtherabbit wrote on 2023-09-30, 19:21:
No, its just like previous code, but with MPU init done before dump.
So it will work as before.
Reply 254 of 1148, by maxtherabbit
Maelgrum wrote on 2023-09-30, 19:24:
Ok here's the output from the AWE32 on this version of the dumper
Reply 255 of 1148, by Maelgrum
maxtherabbit wrote on 2023-09-30, 19:35:
Just as expected - second byte is 0x40.
Thanks, maxtherabbit !
Reply 256 of 1148, by Gmlb256
Dump from CT4520 AWE64 with that version of SB16DUMP.
Reply 257 of 1148, by S95Sedan
Maelgrum wrote on 2023-09-30, 19:22:
Thanks, S95Sedan !
4 and 5 seem to be ground;
http://midi.teragonaudio.com/hardware/pc_intfc.htm
Reply 258 of 1148, by georgel
Maelgrum wrote on 2023-09-30, 19:39:
Nothing unusual - it points to the beginning and end of an empty buffer 40h. When UART is initialized via SB command 34h that is its initial value too. Not sure about the MPU interface though, I made some manual tests but at one point the sound card entered the usual UART mode that can be exited via 8052 reset only.
Reply 259 of 1148, by Maelgrum
Thank you all !
Now i can try to code real dumper. First version will be dedicated V4.13 dumper as proof of concept.
