DOSBox-X branch
Reply 2400 of 2419, by analog_programmer
Yoghoo wrote on 2024-07-09, 11:33:
That is correct. You mounted another drive. C: is empty as all Dosbox-X files are on your Z: drive.
If your directory is not empty and you don't see them on C: then that is another problem though. Never tried it on Linux so can't help with that. I set nocachedir to true in the conf file btw as sometimes copied over files only showed up after a Dosbox-X restart.
Yes, DOSBox-X files are on virtual Z: drive, as they are in the case with original DOSBox, but the directory which I'm trying to mount as virtual C: drive is not empty and it seems that it is not accessible by the linux snap package version of DOSBox-X. There's no such a problem with original DOSBox, but is is installed from normal internet repo, not in software package like snap or flatpak.
The files in snap package installations can not be edited, added, deleted, replaced directly. Again, I'm avoiding this kind of software linux packages, but I can't find any (un)official repos for DOSBox-X to install it "the normal way".
Tried on Lubuntu 22.04.4.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 2401 of 2419, by Yoghoo
analog_programmer wrote on 2024-07-09, 11:47:
Yes, DOSBox-X files are on virtual Z: drive, as they are in the case with original DOSBox, but the directory which I'm trying to […]
Don't know if this applies to you but from https://github.com/flathub/com.dosbox_x.DOSBox-X:
Limitations
For security reasons, this Flatpak is sandboxed and only has access to the user's Home folder. You should place any files you need within DOSBox-X in that folder (or in a subfolder). Alternatively you can allow additional access with the override command. But note that this does not work for all directories as some (like /usr) have special restrictions. For instance, to allow access to /run/media where USB devices are typically mounted, run the following command:
flatpak override --filesystem=/run/media com.dosbox_x.DOSBox-X
Reply 2402 of 2419, by analog_programmer
Yoghoo wrote on 2024-07-09, 12:00:
Don't know if this applies to you but from https://github.com/flathub/com.dosbox_x.DOSBox-X: […]
Limitations
Thank you! I've missed this info. I'll try to mount some subfolder in user's "Home" folder.
P.S. So, it is not a problem of the DOSBox-X software snap/flatpak package, but in general a problem with those type of installations. One more reason to not use these snaps/flatpaks at all 😀
P.S.2. The "Home" subfolder trick did not work 🙁
Reply 2403 of 2419, by analog_programmer
Limitations
Ok, the solution for me turned out to be not to mount "/home/{mounted subdir}", but "/home/{USER}/{mounted subdir}". And it's pretty inconvenient, still better than nothing.
P.S. The problem was really due to software packages limitation. Working solution for DOSBox-X snap package in my case (with access to second HDD): "sudo snap connect dosbox-x:removable-media" and after this any directory on the second HDD can be mounted as DOSBox-X virtual HDD just like in the original DOSBox.
Reply 2404 of 2419, by JSO
I can't make network work with Pcap or slirp. Because I noticed that 98SE and ME are running a little bit faster in DOSBox x instead of PCem (I don't use 86Box is very incompatible for me), I wanted to make some 3Dfx games testing.
Why is so difficult?
DOS IS THE POWER OF OUR CHILDHOOD MEMORIES!
Reply 2405 of 2419, by Duffman
@JSO
Why is 86Box incompatible for you?
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 2406 of 2419, by JSO
Many 3Dfx games are running with glitches and low fps. I experienced many crashes when I was installing drivers and etc. PCem for me is solid. Whatever build I had choose. From 386 to PII and from DOS, Windows 3.x to NT 3.1, NT 3.51, OS/2 2.1x, OS/2 Warp 3 and OS/2 Warp 4, Windows 9x, ME and 2000.
Reply 2407 of 2419, by almeath
PCem and 86Box emulate a complete x86 PC, down to the individual hardware components. So that is why you will often experience more accurate and stable 3dfx emulation in PCem, especially if running Windows 95/98 games. 3dfx support in DOSBox-X is achieved through direct software emulation of a Voodoo card, or via hardware pass-through such as OpenGlide.
It sounds like you are not happy with the level of accuracy or performance using the software emulation mode, so you only have two choices. Try the same games with the hardware or pass-through 3dfx emulation mode - for which there are extensive instructions on the DOSBox-X website, or try another variant of DOSBox (i.e Staging, Pure) which use different code to emulate the Voodoo card in software. The problem with the latter is that support for Windows 95/98 will be more limited and unstable.
DOSBox SVN for macOS (x86-64) - customized with Munt MT-32, Nuked OPL3, 3dfx Voodoo, Extra RAM, Large HD, and more.
https://github.com/almeath/DOSBox-SVN-64-bit-for-macOS
Reply 2408 of 2419, by buckeye
Just installed Dosbox-x on my XP system having hopes of playing Sierra's Front Page Sports Football Pro 95. Tried running it on D-fend but it always
crashes at halftime during a game so that led me to try another front end.
The game installs fine but when running the "hike.exe" I get this error saying can't run the game on a network. This system is "stand alone" not on
a network so can't see why that's coming up unless there's a network setting that's on by default in Dosbox-x? The other culprit could be I have the
game installed under D-fend in another directory however that's not mounted.
Sierra games can be finicky, up to this point I have only been able to get this game running on Pcem. Any thoughts or ideas would be a big help thanks!
Intel SE440BX P3 450 256MB 80GB SSD Asus V7700 GF2 64mb SB 32pnp 350W 98SE
Reply 2409 of 2419, by buckeye
buckeye wrote on 2024-10-28, 14:29:
Just installed Dosbox-x on my XP system having hopes of playing Sierra's Front Page Sports Football Pro 95. Tried running it on […]
Tried running the game on regular dosbox latest version and it runs to a point. When the game reaches halftime it crashes to dos prompt with message
"palette.opp:27 error reading palette information". Apparently this is an error common with other sierra sports games running through dosbox.
This has something to do with copyright protection stuff but this is a legit copy but dosbox for whatever reason sets it off anyways.
Looking at other posts there is a mention of something called "TOUCH" which I have no clue what that is and searches have come come up empty so far.
Think I'm just going to run this game with PCEM or real hardware (Pentium 233mhz based is slowest I got) as this rabbit hole is getting too deep.
Reply 2411 of 2419, by jjdelalamo
No real fullscreen on dosbox-x. Need 640x480 60Hz for CRT monitor.
I don't know what I'm doing wrong but I can't get doxbox-x set to fullscreen mode.
What I'm trying to do is to get fullscreen at 640x480 60Hz to get as close as possible to the real game image on a PC of the time.
I know it's possible because with dosbox-stagging I get it without problem with this configuration:
fullscreen = true
display = auto
fullresolution = 640x480
#fulldouble = true
windowresolution = desktop
viewport_resolution = fit
window_position = auto
window_decorations = true
transparency = 0
host_rate = auto
vsync = true
doublebuffer = true
vsync_skip = 7000
presentation_mode = auto
output = ddraw
texture_renderer = auto
waitonerror = true
priority = auto auto
mute_when_inactive = false
pause_when_inactive = false
mapperfile = mapper-sdl2-0.80.0-alpha.map
screensaver = auto
I want to get it with dosbox-x because it is the only port that supports LFN which for me is a must.
Last version of dosbox-x
W10 at 1600x1200 85hz on a CRT monitor
I have tried changing the “fullresolution” parameter to all values, I have also tried all the possibilities of the “output” parameter. The only thing I get when I switch from windowed to full resolution is that the window changes a little bit in size (depending on the resolution I have set) and that the borders don't appear. If I match the resolution of fullresolution = 1600x1200 it obviously covers the whole screen, but I understand that as a frameless window, not as a full screen.
One of my configurations, I've tried many, many, many:
[sdl]
fullscreen = true
fulldouble = false
fullresolution = 800x600
windowposition =
display = 0
output = ddraw
vsync = true
doublebuffer = true
videodriver =
transparency = 0
maximize = false
autolock = false
autolock_feedback = beep
middle_unlock = manual
clip_mouse_button = right
clip_key_modifier = shift
clip_paste_bios = default
clip_paste_speed = 30
sensitivity = 100
usesystemcursor = false
mouse_emulation = locked
mouse_wheel_key = -1
waitonerror = true
priority = higher,normal
mapperfile = mapper-dosbox-x.map
usescancodes = auto
overscan = 0
titlebar =
showbasic = true
showdetails = false
showmenu = true
[render]
frameskip = 0
aspect = true
# aspect_ratio = 0:0
char9 = true
euro = -1
# doublescan = true
# scaler = normal2x
glshader = none
pixelshader = none
autofit = true
monochrome_pal = green
Could someone help me please?
Reply 2412 of 2419, by MystikShadows
Seems I can't get breadbox ensemble to work on DosBox-X.
went through the CD install process. Rebooted DosBox X and I get invalid font file in UserData/Font directory are all the files Berkeley through to Universi spread out through 17 font files. Te install also reported no error while it was installing.
Help 😀
Reply 2413 of 2419, by igermi
I posted this in the wrong area- but it might help someone else.
I was trying to make dosbox-x work for me but it would not recognize my steering wheel and racing pedals, nor any of my conventional controllers no matter what I did. I figured this out by researching today- this was because I didn't know any better and I installed SDL1 version.
Uninstalling SDL1 and installing SDL2 fixed it!
I wanted to try this over dosbox ECE for indycar racing 2 because it offers save states. I make fan content for ICR2 and sometimes this game can rarely crash, throwing 2 hours of work in the trash. Now if I save state every now and then it can be simple to turn back time if something strange happens.
Thank you very much for the work you have done on this!!!
One thing I would like to do (and there is probably a way). I like the graphics set to stretch only 4:3 when I go full screen, and I see there is an option to only let it do this. I also like to set it to "pixel pefect" so it looks raw. Is there a way to default this so it stays in setup like this each time I re-load? or do I need to set this each time I start playing?
Reply 2414 of 2419, by Dracolich
I've been enjoying dosbox-x for about a year now, especially because of the Daum-like menu bar and save states. Everything had been working nicely through the 20241002 release. When I updated to the 20250101 release, using the same dosbox-x.conf, something happened to the video mode that I can't figure out. So far I've only noticed it in QuikMenu - it launches with an error about not enough memory and then appears in a low res with vertically stretched icons and status bars. I can load the 20241002 release, or Staging, or vanilla DOSBox, to correct the QuikMenu screen; but the next time I use 20250101 it will do the same thing.
I use the SDL2 release and it happens in both Windows 10 (both mingw and vs) and Slackware Linux (using the Fedora el8 rpm). In dosbox-x.conf I use svga_s3 with 4MB memory and Pentium with cycles=max and 64MB ram, and hma, ems, and xms are enabled. I've tried some different settings for the machine, cpu and ram, and disabling ems, but it is not making any difference. I do have an AUTOEXEC.BAT that normally runs when mounting the C drive folder, and I have tried it without the AUTOEXEC. Still no difference.
See the attached screenshots that show my QuikMenu before and after, as well as the dosbox-x.conf
Update 02/11: After updating to the new 20250201 release, which I just noticed two days ago and includes a lot of VGA and VESA fixes, my QuikMenu problem is gone.
Reply 2415 of 2419, by igermi
I noticed from time to time, dosbox-x itself like to crash in windows when I make a save-state. This does not happen all of the time. Normally if I can get it to save- it will save time and time again during that play session. (this is with ICR2 - Indycar Racing 2) I'm not sure if this is something others have seen or if there is something obvious I should be checking.
Reply 2416 of 2419, by TheGreatCodeholio
igermi wrote on 2025-02-16, 16:11:
The savestate system is very incomplete and will not preserve anything beyond basic state. It's OK for anything that doesn't use XMS/EMS. It doesn't preserve hard drive state. Windows uses it's own filesystem driver and hard disk support so you're probably confusing Windows by save stating both application state and system state including the state of the disk and the filesystem. Don't save state with guest OSes for that reason, please.
This isn't like save stating your progress while running an NES or SNES ROM image. There is WAY more state to preserve.
DOSBox-X project: more emulation better accuracy.
DOSLIB and DOSLIB2: Learn how to tinker and hack hardware and software from DOS.
Reply 2417 of 2419, by igermi
TheGreatCodeholio wrote on 2025-03-17, 17:09:
Thank you for the reply. Although I don't understand the intimate details of what's happening under the hood, I see what your mean. My save states are just in 1 game (ICR2). I moved from dosbox ece to dosbox-x mainly because of save states as there are issues with the game crashing every now and then and when it does I lose 2+ hours of racing progress sometimes. (this has been a problem for 30+ years). But I want to make sure I described things clearly- These are 2 different crashes- icr2 has a divide by 0 bug which throws it back to the dosbox cli. The dosbox-x crash is induced seemingly randomly when I try and make a save state just incase I would experience the divide by 0 bug. The strange thing is that dosbox-x itself is crashing- not icr2. But it does not happen every time. It crashes when it tries to write a save- not load a save. If I have a problem, and then I re-load dosbox-x and start icr2 again- things may write fine and when they do they always will each time I try and save my progress during this session- no matter if I do 1 save or say 10, it does not matter.
Reply 2418 of 2419, by feda
igermi, are you playin the DOS or the Windows version? If it's the latter, you might have better luck using VMware which has much more stable save states (called snapshots) that are okay to use in Windows.
Reply 2419 of 2419, by igermi
feda wrote on 2025-03-18, 19:14:
Thank you for your reply! I play icr2 on the standard dos version which is from 1995. The game is patched to the latest version, which was only 1 patch from back in the day.
