Reply 25308 of 59804, by mrau
root42 wrote:
Thanks to keropi I've got this nice thing here in the mail:
You can expect a video reviewing it in the next week or so. Looking forward to hooking up my SC55 to it!
since i' m too stupid to find this myself - what does the zilog do on the board? iirc a cpu of comparable power could not pull off midi in most cases;
and what is that intelligent midi thing? does it magically fix all intelligent mode troubles?
Reply 25309 of 59804, by luckybob
The whole board is just a specialized Micro controller. The Z80 processor was INCREDIBLY cheap and easy to use. It is right up there with the 6502 and 8051. Rather than make a custom micro chip, you could slap a z80 on a board with a bit of ram/rom and have it do all the work.
It is just a small cpu whose whole purpose in life is to watch the isa bus, take any data given to it, and translate that to midi signals. This was a VERY common thing to do. Quite a few early scsi cards did the same thing. including some top-shelf serial/parallel cards. Even some very early Ethernet cards have them. But that was short lived.
Reply 25310 of 59804, by keropi
in this case this is a Z8 MCU , not a full Z80 cpu. It does stuff that it needs to do very quick and it's clocked at 12mhz.
The card is compatible 100% with the Roland "intelligent mode" functions, the firmware is just a port to the Z8 mcu from Roland's Hitachi (iirc) MCU so you don't need any drivers or other software to run the software that requires it
Reply 25311 of 59804, by Thermalwrong
Today's prize is the Intel TC430HX motherboard with all the optional extras integrated:
The attachment tc430hx.jpg is no longer available
  • Intel 430HX chipset for Socket 7 processors
  • Powerful S3 Virge DX integrated PCI graphics with 2MB of EDO memory
  • Supports the latest Intel Pentium 233MHz MMX processor
  • 512KB of L2 Cache integrated
  • SRS 3D Yamaha OPL3-SA audio with OPL4 WaveTable
  • The latest ATX format motherboard design with Universal Serial Bus ports
Installing Windows 98SE on this has been great - everything just works out of the box, all the drivers are already there and there's OPL3 or OPL4 options selectable for MIDI playback. The seller was selling it as broken, which it is if you plug the jumpers in like the picture, but it works when they're installed where the manual says they go 😁
I guess this would be good to pair with the Voodoo 1, but it's working pretty well with nothing plugged in as well (except when the processor gets busy the screen gets wavey because that's what happens when you put the IGP that far away from the port and run it past the cache chips)
Reply 25312 of 59804, by Bancho
Thermalwrong wrote:
Today's prize is the Intel TC430HX motherboard with all the optional extras integrated: […]
Man that's a beauty of a board! Something about ATX socket 7 boards. Onboard OPL 3 & 4 and 3 isa slots!! That would be perfect for a mega sound card build!
Reply 25313 of 59804, by keropi
wow that must have been an elite board or something back then, black ss7 mobo? 😮
Reply 25314 of 59804, by cyclone3d
With all the talk of Cyrix 5x86 CPUs lately, imagine my surprise when somebody stuck up this lot with a 5x86 120.
Also has an Intel 486 DX4 100 which I don't have yet as well as a TI 486DLC-33 and a Cyrix FasMath 40Mhz.
The attachment top.jpg is no longer available
The attachment bottom.jpg is no longer available
Initial asking price was too much so I put in an offer and it was accepted.. woohoo!
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 25315 of 59804, by Thermalwrong
According to the BIOS string, it's a "1.00.xx.DH05 MBD001078 Millennia® LXA/ClientPro® MTA (Tucson P5/TC430HX)", which appears to be one of these:
https://books.google.co.uk/books?id=6TsEAAAAM … ge%20dx&f=false
So not particularly high end, but lucky that it has "integrated wavetable". Sadly, as I'm running it, it's getting less happy and more crashy, so I guess there are some issues to look into after all 😀
Reply 25316 of 59804, by SW-SSG
Maximum FSB will officially be 66MHz, and PCB colour meant nothing about the "eliteness" of an MB back then. As it's an Intel motherboard, it's likely closer to dark green anyway.
Reply 25317 of 59804, by SEGamer
Found two sound cards on my list this past week: (sellers' photos)
Interwave based sound card:
The attachment s-l16002.jpg is no longer available
And an Awe64 Gold hiding in this lot:
The attachment s-l1600.jpg is no longer available
NintendoAge | VCFed
Reply 25318 of 59804, by Thallanor
I can tell it was an incredible deal when you're buying them by the pound!
Reply 25319 of 59804, by Murugan
Not from yesterday but the weekend 😀
Got these 3 for 70€ which is pretty good imho.
The Olivetti has had some TLC scrub but due to keyboard error, I can't get it to post further. I think the HD is toast, it squeaks like an old wheel.
I have enough keyboards but this Olivetti doesn't seem to have a classic keyboard connector so any help is appreciated.
The seller also gave me the MS mouse that came with it but it has an parallel or serial adapter attached so I'm guessing the keyboard also needs something like that?
I need to find more info on the screen too. Not sure if it's VGA.
The Tandy should work according to a picture he sent me before but that is on the menu today. First one I've ever had....
Should I ask MS for the cellphone :p?
This also came in:
Not in the picture: an XT psu that has some damage to the switch so I need to look into that.
Traded this + Voodoo3 2000 for my boxed AWE64 Gold
http://www.pixelatedarcade.com/pictures/192
Reply 25320 of 59804, by cyclone3d
Heh. Not sure it was an incredible deal, but it was a decent deal considering the Cyrix 5x86 120.
This should complete my attainable high-end socket 3 CPUs anyway.
Intel 486 DX4-100
AMD 5x86 133
Cyrix 5x86 120GP
Intel PODP5V83 (Pentium 83Mhz)
YMF7x4 Guide
Reply 25321 of 59804, by derSammler
Seeing how beaten those CPUs are, what makes you think the Cyrix even still works?
Reply 25322 of 59804, by Thallanor
cyclone3d wrote:
Heh. Not sure it was an incredible deal, but it was a decent deal considering the Cyrix 5x86 120. […]
Intel 486 DX4-100
AMD 5x86 133
Cyrix 5x86 120GP
That is cool. I now have a small collection of CPUs but have yet to inventory them properly. The biggest issue that I am starting to run into now is finding heatsinks and fans for older CPUs. An example would be my 486/66 which I just feel more comfortable having a heatsink and fan on. But the socket doesn't have anything to attach to. In this case, I was lucky and a friend gave me a heatsink and fan that actually clips to the edges of the CPU itself. At least as my CPUs get newer, I move onto more standard sockets. 😀
Reply 25323 of 59804, by cyclone3d
There are only 3 CPUs (The 2x IT's and the one DLC) in that lot that look like they would not work.. and maybe one of the 486SX chips.
I'm guessing the ones that are physically broken were broken when the dummy was trying to remove the heatsinks for scrapping purposes.
The others all just have bent pins which are easy to fix.
YMF7x4 Guide
Reply 25324 of 59804, by cyclone3d
Intel 486 DX4-100
AMD 5x86 133
Cyrix 5x86 120GP
I know the feeling. Luckily for me I came across a couple different lots of CPU coolers. Even have some brand new ones for socket 3 CPUs.
I wasn't willing to spend the absurd amount that a lot of people try to sell a single cooler for.
YMF7x4 Guide
Reply 25325 of 59804, by dionb
Was very happy to see the postman today - three separate purchases arrived together:
- two TEAC 5.25" 1.2MB floppies with 1980s vintage black front. Also a freebie 3.5" FDD and ATAPI ZIP100 drive used as packing material to fill out the box 😁
- an IBM rubber dome keyboard to go with my keyboardless PC330
- an ECS SL486E motherboard with EISA & VLB, if not new, at least in original box with original manual and EISA config disks. Too bad about the soldered Dallas RTC though...
Reply 25326 of 59804, by Murugan
Nice on Dionb
Reply 25327 of 59804, by stamasd
Much better though than a leaking barrel battery.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
