Reply 2540 of 2663, by Falcosoft
Spesek wrote on 2026-06-22, 14:42:
Falco, I can't seem to get presets to work. It always uses the last configuration preset I selected. […]
I have a total of 6 presets, i believe that most are default:
- Default_000
- MuntVsti_001
- OPL3Vsti_002
- scvaRender_003
- syxg50Render_004
- WinMM_MultiPortVsti_005
The command i use with a random file (silent removed so i can see the gui):
wine MidiPlayer.exe "Z:\home\spessasus\htdocs\spessasynth_core\tests\midi_file\generated\auto_wah.mid" "/preset 3" "/render" "/close"
for scva
wine MidiPlayer.exe "Z:\home\spessasus\htdocs\spessasynth_core\tests\midi_file\generated\auto_wah.mid" "/preset 4" "/render" "/close"
for syxg.
If I had manually selected scva, both will render as scva. I tried 4 and 5 respectively as well, but that didn't work.
I attached the ini files here:
The attachment scvaRender_003.ini is no longer available
The attachment syxg50Render_004.ini is no longer available
They seem fine to me and have correct paths.
Ideas as for why it might not be working? The FSMP works with close, render and silenttray, so the arguments are definitely parsed.
PS: I forgot to mention but the new dark mode looks amazing!
The attachment Screenshot_20260622_164020.png is no longer available
Hi,
First you should check that your presets work through the GUI or not. That is double click them (or press Apply) on the configuration preset loading dialog and check that the proper VSTi plugins are loaded or not.
Website, Youtube
VST Midi Driver Midi Mapper
x86 microarchitecture benchmark (MandelX)
Reply 2541 of 2663, by Spesek
Falcosoft wrote on 2026-06-22, 14:53:
- Default_000
- MuntVsti_001
- OPL3Vsti_002
- scvaRender_003
- syxg50Render_004
for scva
for syxg.
Hi,
Yes, loading either syxg or scva manually works just fine. The VSTs load correctly. Then the cli version uses the vst i selected through the GUI, completely ignoring the passed argument.
@EDIT: An idea: maybe make FSMP write the arguments it received and the currently selected configuration preset to stdout for debugging? Wouldn't hurt, i think.
Reply 2542 of 2663, by Falcosoft
Spesek wrote on 2026-06-22, 14:57:
- Default_000
- MuntVsti_001
- OPL3Vsti_002
- scvaRender_003
- syxg50Render_004
for scva
for syxg.
Hi,
Then make sure there are no other presets in the preset folder with the same suffix as the required ones. I have just tested again and I experienced no problems.
Also you should try to remove the double quotes around the arguments (except the filename). They are not required at least on Windows. That is:
MidiPlayer.exe "filename" /preset 1 /render /close
BTW, GUI applications have no standard stdout on Windows. You have to explicitly open and attach a console window to the application to use stdout.
You can use OutputDebugString but you have to get a special app (like SysInternals's Dbgview.exe) to watch the output.
Website, Youtube
Reply 2543 of 2663, by Spesek
I removed all other presets, the config window nly shows syxg50 and scva now,
I tried 0, 1, 2, quotes and no quotes, it's always scva since i set it to that before.
So another approach: where does FSMP store the last selected config? I suppose i can just change that file if the options aren't recognized.
Falcosoft wrote on 2026-06-22, 15:02:
Then maybe in the "about" window? A small line with passed command line options.
Reply 2544 of 2663, by Falcosoft
Spesek wrote on 2026-06-22, 15:22:
I removed all other presets, the config window nly shows syxg50 and scva now, I tried 0, 1, 2, quotes and no quotes, it's always […]
Here is a debug a 32-bit version that opens a console windows and prints the found presetnum and preset file name:
The attachment MidiPlayer_dbg.zip is no longer available
The attachment debug.png is no longer available
Website, Youtube
Reply 2545 of 2663, by Spesek
For me it only shows "Found PresetNum:" with the correct number. So it sees the argument correctly, but doesn't find the ini file? Strange, given that the configuration preset window shows the list correctly.
Reply 2546 of 2663, by Falcosoft
Spesek wrote on 2026-06-22, 15:34:
Here is another debug version that prints more detailed info about the findfileFirst/FindfileNext API calls (and the found preset folder)
The attachment MidiPlayer_dbg2.zip is no longer available
The attachment debug2.png is no longer available
I'm starting to suspect that this is another Wine quirk...
Website, Youtube
Reply 2547 of 2663, by Spesek
CMD shows:
Found PresetNum: 2
Preset Folder: Z:\home\spessasus\Desktop\clutter\MidiPlayer x86\Preset\
Im in FindfirstFile
Im in FindNextFile
Also, I think you can test wine without dualbooting linux via WSL2. It supports GUI apps. I don't do anything special, just:
wine MidiPlayer.exe "Z:\home\spessasus\htdocs\spessasynth_core\tests\midi_file\generated\auto_wah.mid" /preset 2
And it's a normal wine install on arch, which is supported through wsl2
Reply 2548 of 2663, by Falcosoft
Spesek wrote on 2026-06-22, 15:47:
CMD shows: […]
CMD shows:
Found PresetNum: 2
Im in FindfirstFile
Im in FindNextFile
I'm using a SoundBlaster Audigy 2 ZS so I'm on Windows 10 1809 where there is no WSL2 ...
BTW, Is the Preset Folder: "Z:\home\spessasus\Desktop\clutter\MidiPlayer x86\Preset\" the expected one?
@Edit:
Last debug version that also prints the found ini file names. Please, run it the last time 😀
The attachment MidiPlayer_dbg3.zip is no longer available
The attachment debug3.png is no longer available
Website, Youtube
Reply 2549 of 2663, by Spesek
Found PresetNum: 2
Im in FindfirstFile
INI name: scvaRender_003.ini
Im in FindNextFile
INI name: syxg50Render_004.ini
So it does see them!
@Edit: About the audigy, I found quite a few mentions of it in the linux kernel, so i think it has a driver for it. Maybe you'll join the penguin side? :-]
Reply 2550 of 2663, by Falcosoft
Spesek wrote on 2026-06-22, 16:01:
So it does see them! […]
Found PresetNum: 2
Im in FindfirstFile
Im in FindNextFile
@Edit: About the audigy, I found quite a few mentions of it in the linux kernel, so i think it has a driver for it :-]
1. The problem is that the found presetNum is 2 but there is no INI file found with _002 suffix !
2. I was talking about Windows 10 😀 Windows 10 versions after 1809 kills my Audigy in different ways...
Website, Youtube
Reply 2551 of 2663, by Spesek
Welp, yeah. The suffix was it, it works now.
And I know that you meant windows breaking the driver in the new versions, so I mentioned that linux has essentially timeless drivers (because they are source code, not compiled) which always work on the latest version! For example i got 5.1 through spdif working out of the box on linux, while on windows it either requires an ancient sound card or shady realtek drivers. It's an old codec called DTS Interactive and modern sound cards don't really support it.
Reply 2552 of 2663, by Falcosoft
Spesek wrote on 2026-06-22, 16:15:
1. OK, I'm glad it finally worked.
2. OK, But on Linux there is no Creative's SoundFont Bank manager (sfman32) and this is the most important component for me because of SF2 engine related testing .
Website, Youtube
Reply 2554 of 2663, by Falcosoft
Spesek wrote on 2026-06-22, 16:22:
https://sourceforge.net/projects/qsfm/ […]
@Edit: This is the first result thatcame up, I don't actually have a sound blaster to test.
@Edit 2: There's also this https://flaterco.com/kb/audio/Semi_MIDI_Linux.html
It does not seem to use the same API as creative's driver 😀
For me sfman32 is important because of compatibility testing of my Midi Player that uses the API of sfman32.
Website, Youtube
Reply 2555 of 2663, by RetroGamer4Ever
DTS Interactive is just plain ole PCM to DTS bitstream encoding and nothing terribly great in today's audio realms. I'm not sure what use you have for it, but there are many work-around jiggles to get it working on a variety of hardware.
Reply 2556 of 2663, by Spesek
RetroGamer4Ever wrote on 2026-06-22, 23:14:
The use i have for it is because my sound system only accepts either 6 channel analog or spdit dts/dolby digital for 5.1 signal. And the former causes hissing and buzzing issues when my GPU is in use, while optical has none of these. And I know that there are workarounds, but they are, well, workarounds! It's not just plug-n-play, it involves downloading weird "realtek audio unlock" drivers from old windows versions that can be riddled with viruses. While on linux it just worked, like stereo codec on windows. No workaround needed. I'm assuming it's the same case for the soundblaster, esp. since Falco mentioned that it breaks on newer windows builds.
PS: Falco, I also forgot to thank you for helping me figure this out, the automated test renderer is working flawlessly now. Thanks again!
Reply 2557 of 2663, by Falcosoft
Spesek wrote on 2026-06-22, 23:26:
You're welcome 😀
BTW, I have added system global named mutexes to prevent simultaneous writes to shared registry/ini file resources. I could not extensively test it so your feedback is welcome.
https://falcosoft.hu/midiplayer_66_test.zip
Website, Youtube
Reply 2558 of 2663, by AliceGrimaude
Hey Falcosoft, quick thing to note here; we recently moved to a Windows 11 system and have found that the volume slider in Midi Player doesn't seem to be working for any of our external sound modules (SC-55ST, SC-8850) anymore, not like how it worked with our previous system anyway.
We could switch to Sysex for Volume/Balance, but is this maybe more to put on updates in how Windows 11 handles external midi modules these days?
We certainly don't remember volume controls behaving this way in the past, at least for external hardware.
Reply 2559 of 2663, by Falcosoft
AliceGrimaude wrote on 2026-07-05, 16:56:
Hi,
For external Midi modules you always had to select the 'Use SysEx for Volume/Balance' option unless you plugged the audio output of the Midi module back to the line-in of the sound card. Otherwise there is no way to alter the volume of an external Midi module with the Windows mixer. If you plug the Midi module into the line-in of the sound card then you should unmute the line-in source of your sound card and then you can use the Windows mixer.
This is not Windows 11 specific at all. This worked the same way on older Windows versions as well. Actually that's the main reason why the 'Use SysEx for Volume/Balance' option exists at all.
Website, Youtube
