Reply 260 of 295, by Deunan
wbahnassi wrote on 2025-07-25, 08:13:Yes, the POST card shows a sequence. The sequence changes between BIOS vendors (Ami, Award, Phoenix). I think I'm currently on an Ami one.
The current startup sequence I get is a few codes that run very fast, then it pauses on 1A 19 and gives the VGA error beep pattern. . After that, it continues to roll again against a few codes until it lands on either 30 24 or 30 25... it's random between these two (24 and 25).
Odd, these codes don't make much sense for graphics card error. Maybe there is a problem with stuck address bit on the BIOS ROM after all?
Since you are getting codes on the card, assuming those are not glitched, the lower 8 bits of data and addresses up to A9 seem to work fine. Could be higher address lines or upper data byte has issues. You did mention a short on D15 line to GND in one of the slots, could be that caused some issues - the problem is this is driven directly from one of the big chips. Did you check the voltage on that line afterwards, is it a valid logic level? Does it ever toggle during boot sequence?
